RobMan
Is there any chance the primer got contaminated somehow?
I have. Some paint stocks just get old and the components (pigment, vehicle, binder) seem to separate. Shaking the can a long time helps.When spraying it went on as gloss black but when I came back about 20 mins later it had clouded over to what you see now. Never had this happen before.
Good point, I'll try some 1200 wet sanding followed by some rubbing compound to see if I can bring up the gloss level.Looks way better, and I'd suspect you could use a little light compound to get a satin gloss out of it as is.
I know what you mean about the thought of putting the bearing races on backwards, I think a double checked myself about a half dozen times because it would be a disaster. As for the bearings I just used a small dab of bearing grease to hold the bearings in place until I could slip the race in place. I also had to remind myself to check the orientation of the center bearing cap using the marks the alignment pin opening makes. The covers look great and if the engine cases look as good you will probably have a twinge of anxiety when getting the completed engine ready to go back in the frame.While I was geared up for the 2K clear coat, I sprayed the top and bottom engine cases as well as the side cases.
I waited a few days for the clear to harden then began the re-assembly of the bottom end.
Started to put the crankshaft back together. Getting those rollers in takes some patience. To keep them from falling out, I put an elastic band around the cage and then slipped the rollers in one by one while turning the cage so the empty slot was always on top. While I did the outer bearings I left the elastics wrapped around the con rods to keep the inner races from moving.
Since the outer races are removeable, it's easy to put them on the wrong way. I had the remove the outer race on the rotor side as it was not oriented such that the oil hole in the race was lined up with the oil hole in the upper case. That would have been a disaster!
Thanks. I'm doing all of this work in the basement (except for painting) so when it comes time to put the engine in the frame I will bring everything to the garage. My plan is to install the rotor and stator to be able to do the cam timing and then I will remove that in order to lighten the engine when I bring it upstairs. I won't install the starter motor nor anything on the clutch side. I will do the frame over engine approach so hopefully nothing gets scratchedThe covers look great and if the engine cases look as good you will probably have a twinge of anxiety when getting the completed engine ready to go back in the frame.
Very good ideas, every pound/kilo less you have to shift is a good thing. I have decided there is definitely changes happening in the universe where objects are gradually accumulating mass and gravity is exerting more pull on those objects as well otherwise I would not be straining to lift objects that were no problem only a "few" years ago.Thanks. I'm doing all of this work in the basement (except for painting) so when it comes time to put the engine in the frame I will bring everything to the garage. My plan is to install the rotor and stator to be able to do the cam timing and then I will remove that in order to lighten the engine when I bring it upstairs. I won't install the starter motor nor anything on the clutch side. I will do the frame over engine approach so hopefully nothing gets scratched
I just read this morning that our moon is slowly drifting away from earth, so it makes sense that it is helping us lift heavy stuff less and less by the year. /sVery good ideas, every pound/kilo less you have to shift is a good thing. I have decided there is definitely changes happening in the universe where objects are gradually accumulating mass and gravity is exerting more pull on those objects as well otherwise I would not be straining to lift objects that were no problem only a "few" years ago.
I remember when I worked at a dealer I had no problem removing a CB450 engine on my own - that was a long time ago and yes every pound counts now.Very good ideas, every pound/kilo less you have to shift is a good thing. I have decided there is definitely changes happening in the universe where objects are gradually accumulating mass and gravity is exerting more pull on those objects as well otherwise I would not be straining to lift objects that were no problem only a "few" years ago.
That was the Spraymax 2K Clear Glamour (368 0061)? I've occasionally seen a Clear Satin (368 0067) alternative on the shelf at my local supplier.Waited a couple of days and applied a coat of Spray Max 2K. Not as glossy as I would like so will apply a glossier clear coat in a few days.
I bought the Clear Satin (368 0067) mainly to do the cases and thought I would use it on the headlight bucket to protect it a bit better, it's almost $50 a can here in Canada and I didn't want to spend that much for the Clear Glamour just for the bucket. My frame is a semi-gloss and the bucket looks dull compared to the frame so I need to get it a bit glossier.That was the Spraymax 2K Clear Glamour (368 0061)? I've occasionally seen a Clear Satin (368 0067) alternative on the shelf at my local supplier.
We do seem to be close in our engine rebuild progress at the moment, just my cases together today. I have enjoyed watching your thread and comparing notes.
In this case I prefer to be the tortoise, slow and sureI thought it was a race!
Have either of you decided whether you plan to install frame over motor or motor into frame?Watching @RobMan 's build makes me ponder all the next steps and what pitfalls might lie in wait!
I was rescued from that ugly situation by Chris Schumann when I sent my 450 head to him. I'd gotten the head in a parts and cash deal for my V65 a few years back from a member of HT who we previously thought was a decent machinist. Apparently he'd blasted the head before thoroughly washing it free of oil and it accumulated globs of media in many nooks and crannies. Chris cleaned it all out for me including the screw/bolt holes.Really glad you caught the blasting media still in the bolt holes and yes could have seized or broke a bolt. I remember another member had that issue when installing cam bearings on the head but can't remember the exact thread. Not sure what I will install next, I am thinking oil pump and clutch next.
I am not sure, the frame over motor is probably easier but I really want to have the engine completely put together before starting the frame and running gear. If I have too many parts of a project going at once I tend to lose track of stuff both figuratively and literally. I was already planning on getting my daughter and my big strong son in law to come visit that weekend.Have either of you decided whether you plan to install frame over motor or motor into frame?
If motor into frame, it will be lighter and smaller without the crankcase side covers, clutch, rotor, etc.
Yup, that was me with the cam bearing. That's why I decided to make sure the bolts were able to go in completely before doing the final assembly.Really glad you caught the blasting media still in the bolt holes and yes could have seized or broke a bolt. I remember another member had that issue when installing cam bearings on the head but can't remember the exact thread. Not sure what I will install next, I am thinking oil pump and clutch next.
Yeah, it does take a lot of time to really clean things out and make sure screws/bolts will not get jammed up by the media.I was rescued from that ugly situation by Chris Schumann when I sent my 450 head to him. I'd gotten the head in a parts and cash deal for my V65 a few years back from a member of HT who we previously thought was a decent machinist. Apparently he'd blasted the head before thoroughly washing it free of oil and it accumulated globs of media in many nooks and crannies. Chris cleaned it all out for me including the screw/bolt holes.
My approach is going to be frame over motor but first I need to bring the engine up from the basement to the garage, so the lighter the better. I will be leaving off the side covers, clutch, rotor, stator and starter motor.Have either of you decided whether you plan to install frame over motor or motor into frame?
You have seen this from my assembly, right?I am not sure, the frame over motor is probably easier but I really want to have the engine completely put together before starting the frame and running gear.
Hopefully either mechanically assisted or with another set of hands - that's a heavy lump of awkward to work against gravity.My approach is going to be frame over motor but first I need to bring the engine up from the basement to the garage, so the lighter the better. I will be leaving off the side covers, clutch, rotor, stator and starter motor.
No I haven't seen this but I definitely take a look. Do you have a link to the thread?You have seen this from my assembly, right?
Engine completely assembled, and the hardest part was standing up the frame and engine together afterward. Then you just start putting pieces on and blocking up the frame for height as needed. The second time around I took the entire front end off, fully assembled, at the steering stem.
Of course, and the original lengthy thread at HT as well.Do you have a link to the thread?
I better finish the assembly while my daughter is visitingHopefully either mechanically assisted or with another set of hands - that's a heavy lump of awkward to work against gravity.
Will definitely review this prior to proceeding with the frame over engine.Of course, and the original lengthy thread at HT as well.
CL450 project reboot, street-legal this time
This attempts to be a synopsis of the nearly 500 posts of my "little red monster" build from another forum long ago... original build thread is here if anyone is interested. CL450 project reboot, street legal this time When I was 19, I built a CL450K5 into a modified class drag bike Ever...www.vintagehondatwins.com
But back to Brad's project now...
It's simple enough, just have the long lower motor mount bolts handy and slip them into the frame and engine as the frame slides over the mounts on the lower case. That will stabilize it enough so you can tip it upright on the bottom of the frame, and go from there.Will definitely review this prior to proceeding with the frame over engine.
Yeah - it's amazing how quickly those things get really heavy. You can get away with using a dolly, just strap it on real well - but a two person with one at the bottom case and the other at the cylinder head makes it manageable. I've never thought to weigh one, but it's got to be pushing 120 pounds without extraneous covers. I think it's 140ish total assembled weight.I better finish the assembly while my daughter is visiting. Maybe I can convince her it's not that heavy!
Good idea about the dolly. I have one that I use to push around my generator - I can use it on the flat areas.Yeah - it's amazing how quickly those things get really heavy. You can get away with using a dolly, just strap it on real well - but a two person with one at the bottom case and the other at the cylinder head makes it manageable. I've never thought to weigh one, but it's got to be pushing 120 pounds without extraneous covers. I think it's 140ish total assembled weight.
Thanks for the offer for the o-rings. I thinks I am pretty much ok for the other sizes as I ordered for the dip stick, drain plug and oil spinner.Wish I had known you needed that O Ring as I have like 24 extra and would have sent you one or two. I too was missing one from my gasket set and ended up ordering from Orings and More. Much cheaper even though you have to order a minimum quantity. Some one in the forum mentioned them in a thread and it is a little bit of a pain to order as you have to go by size not part number. I also have a few other extra Orings I ordered so PM if you are missing something. The engine looks great and I wish i was where you are with my build. Yes find someone with lots of muscle to help haul the beast.
