It's been a while and the honey-do list was long but finally got a bit of time to work on the bike.
I was having a bit of a hanging idle issue (documented in another thread that I will update soon), so I removed the carbs to see if anything was clogged. In the float bowls I found some rusty sediment that was so fine it got past the filter in the petcock. To remove the rust in the tank I initially used vinegar which worked not too bad but even though I coated lightly with Marvel Mystery oil, there was still some flash rust at the bottom of the tank. I then used the Detox C which did a nice job. I did not fully fill the tank with gas as I was still needing to paint it, so flash rust has returned is some areas.
I decided to pull out the POR 15 kit that I bought several years ago but never used. I followed the directions and used the Marine Clean to get out any sludge (there was none but followed the directions to the letter). Rinsed the tank and then used the heat gun to remove any excess water. Next step was the Prep and Ready which removes any rust. Rinsed the tank 3 times with hot water then used the heat gun to get the tank absolutely dry inside. As the tank dried there was a lot of flash rust that developed but the instructions say this is normal and actually lets the sealer bind better to the metal.
Next step was the sealer and I was a little worried since the kit was about 7 years old but the tin was never opened and the contents were still very liquid. After several minutes of mixing I poured the contents of the sealer into the tank and rolled the tank for a good 10 to 15 minutes to ensure all surfaces were coated. I drained the excess sealer into an old paint roller tin in order to verify after a few days that the sealer would harden correctly.
I tilted the tank on end to ensure no sealer would not pool around the cross over tubes or petcock spigot. I came back next morning to find that the cross over tubes were blocked. The sealer is very liquid and I think the sealer from the base of the tank probably slid down and covered the cross overs. I used a piece of bicycle brake cable in a drill with the end splayed to kind of drill out any sealer - it worked like a charm.
After 3 days the sealer in the paint tray hardened up beautifully and the tanks is now sealed.
Now that the tank is sealed and the heat/humidity has dropped, I decided to start painting the tank and side covers. I wiped everything down with laquer thinner, got out my respirator and applied several light coats of Spray Max 2K primer. I will let this sit for a few days and then lightly sand before applying the 3 step candy apple red.
