ballbearian
Bummer, either too long a screw or leftover media bound it up. I never trust blind holes of FSM specs, clean to the bottom then measure.
I think I remember reading about the oil restrictor but couldn't remember which side it was supposed to be on.Pretty much had to be blast media, I'm guessing. Shame it happened to what was otherwise a nice assembly. Brad, another way to know which way the intake cam goes is to look for the oil restrictor orifice. It's in the right side end of the cam where the timing mark is.
That's the truth - it's always something tiny like this. Luckily, it's an accessible one that isn't a really high compression load, so a M6 helicoil should get you back on track - it's looking really good so far.It's part of the process. I think we have all hit a brick wall at some point in our restorations. I was thinking about why the screw was so tight to come out and then it came to me. I probably forgot to run the 6mm tap through that one hole. I did all of the others and had some blast media come out on a few. I suspect because this hole didn't get the tap clean out that some media got between the threads and jammed the screw. A self inflicted wound, haha
I see it as a minor set back. Will look at drilling it out some time today and then will have to go get a helicoil.That's the truth - it's always something tiny like this. Luckily, it's an accessible one that isn't a really high compression load, so a M6 helicoil should get you back on track - it's looking really good so far.
Difficult road leads to beautiful destinations... or so I keep telling myself.
Thanks. The options were a gloss or semi gloss. To me the semi gloss looked more like the factory finish, the gloss was way shinier than what Honda did back in the day.Beautiful parts, like the satin finish.
Good thinking, it's so much easier to do it that way and then assembling the rest of it afterward is easy too. When I had my 450 apart for the frame repairs, I pulled the entire front end off at the steering stem. With tapered rollers it was simple reassembly (well, except for the weight of the whole front end, but it helped that I did the front end first while the rear wheel was off).Not putting any of this on the frame just yet as I want to finish the engine and then lay the frame over the engine for the engine install. Don't want to have a lot of extra weight on the frame when I do this.
I've used it over paint on tanks and the engine side covers on my XL350. I do think it holds up well to gas and other chemicals.has anyone used this 2K clear coat before and how did it stand up to gas spills.
That SprayMax is pretty easy to work with - that VHT Caliper paint, not so much (I've had better luck with Duplicolor engine enamel). Anyway, do a light coat, give it 5 to tack up, light coat again, give it 10, then hit with a good even medium coat. The engine case is textured, so it hides airborne overspray really well, the trick to no getting drips are those first couple of tack coats, and them maintaining a consistent distance with your final coat - it pushes pretty high volume for a rattle can. If you can, keep your air compressor with a nozzle nearby, I've had pretty good luck with correcting a drip if you catch it real wet and feather it out with compressed air.I want to start on the engine next but before I do, I need to clear coat the case. Mine were pretty pitted and lots of oxidized aluminum. I bead blasted, cleaned and painted the cases. I used the VHT caliper paint and cured it in the oven but noticed that it would easily come off with some laquer thinner. I opted to go with the Spray Max 2K clear coat to further protect the painted cases.
From reading the specs it seems like something you don't want to breathe in, so I will do this in the garage with the doors open and wearing a mask.
Question: has anyone used this 2K clear coat before and how did it stand up to gas spills. Anything to watch out for when applying such as too much gives a cloudy finish, easily runs, etc?
Good to know. The specs say it stands up well to chemicals but just wasn't sure about gas.I've used it over paint on tanks and the engine side covers on my XL350. I do think it holds up well to gas and other chemicals.
Thanks for the tips on spraying the 2K and about keeping the compressor on hand if any runs do appear.That SprayMax is pretty easy to work with - that VHT Caliper paint, not so much (I've had better luck with Duplicolor engine enamel). Anyway, do a light coat, give it 5 to tack up, light coat again, give it 10, then hit with a good even medium coat. The engine case is textured, so it hides airborne overspray really well, the trick to no getting drips are those first couple of tack coats, and them maintaining a consistent distance with your final coat - it pushes pretty high volume for a rattle can. If you can, keep your air compressor with a nozzle nearby, I've had pretty good luck with correcting a drip if you catch it real wet and feather it out with compressed air.
Right now the frame is completely stripped. I thought of putting the main stand on then dropping the frame over the engine. In your experience should I pre-assemble anything else before laying it over the engine?All the parts look great. The bike is going to look fabulous.
All I had on the frame was the brake pedal and right footpeg (but mine is different and isn't tied to the centerstand). The footpeg was actually helpful, kind of a handle to work with.Right now the frame is completely stripped. I thought of putting the main stand on then dropping the frame over the engine. In your experience should I pre-assemble anything else before laying it over the engine?
Thanks. I think I will do the main stand and the grab handle used for putting the bike on the main stand.All I had on the frame was the brake pedal and right footpeg (but mine is different and isn't tied to the centerstand). The footpeg was actually helpful, kind of a handle to work with.
Since the engine goes into the frame on the left side and the arm on the centerstand will be sticking out that direction, it might cause some interference. The grab handle will be fine. Have one of the long lower motor mount bolts handy and slip that in first to stabilize things.Thanks. I think I will do the main stand and the grab handle used for putting the bike on the main stand.
Duh, forgot about the arm on the center stand, that's going to make things awkward. I will leave the stand off for the engine install.Since the engine goes into the frame on the left side and the arm on the centerstand will be sticking out that direction
Yeah. That’s not ideal, particularly for clear coat over the engine paint. Speaking of which - how long ago did you do the oven cure?Thanks for the tips on spraying the 2K and about keeping the compressor on hand if any runs do appear.
It's currently 90F with 70% humidity (says it feels like 105F) so I think I'd better wait for cooler temps before spraying.
The label said to cure it must in the oven at 200F for 1 hour, which is what I did.how long ago did you do the oven cure?
Give it a solid few days to off gas before clearcoat, it’ll be way more durable.The label said to cure it must in the oven at 200F for 1 hour, which is what I did.
It's been about 5 weeks since I painted the cases and cured them in the oven. It's supposed to cool down by the end of the week so I will likely tackle this in a couple of days from now.Give it a solid few days to off gas before clearcoat, it’ll be way more durable.
Oh yeah. Plenty of time then. We could definitely use a couple of coolish days down here - send whatever y’all have left over!It's been about 5 weeks since I painted the cases and cured them in the oven. It's supposed to cool down by the end of the week so I will likely tackle this in a couple of days from now.
I also get motivation from other threads. Progress can be slow at times when waiting for parts or in my case it's lots of other projects around the house that need doing.I’m looking forward to seeing some pics of the progress. It is motivating for me to see other folks making progress.
Thanks. I think I have a respirator mask somewhere, I know I have extra cartridges in the workshop. I will definitely use the mask.Spray Maxx 2K is toxic to your lungs, really bad nasty stuff. Only use it in a well ventilated area unless you have a respirator style face mask. The cheap paper painters masks are worthless, minimally a cartridge filter type.
As for durability, it's great. Gas, brake fluid, etc. all clean off easily w/o paint damage. Some carb sprays will leave a cloudy surface.
Good to know, I will take the necessary precautions.When I use it I'm in long sleeves and pants, gloves, goggles and cartridge respirator.
You wouldn't need to strip the chrome to do this. Some 600 and then 800, prime, then 800 again, basecoat and clear.I always liked the look of @birdland's bike, and painted fenders came to mind because of his bike.
I was thinking the same thing, except for the pits and little rust trails that will show up unless feather-edged, which is really hard to do with properly-done chrome. Might take a fair amount of primer and sanding to cover them.You wouldn't need to strip the chrome to do this. Some 600 and then 800, prime, then 800 again, basecoat and clear.
Saw the shout-outs (thanks guys) and thought I'd jump in. This is a better pic, in sunlight - and the most polished the bike has ever been. I have an image somewhere of another of these done over in a deep green tinted battleship grey. It's REALLY nice.I always liked the look of @birdland's bike, and painted fenders came to mind because of his bike.
Looking really good, you've been busy over the winter!Saw the shout-outs (thanks guys) and thought I'd jump in. This is a better pic, in sunlight - and the most polished the bike has ever been. I have an image somewhere of another of these done over in a deep green tinted battleship grey. It's REALLY nice.
EXACTLY like that!Like this....
It didn't feel very humid, but when I checked the weather site for yesterday, it was at 94%. This was a rattle can gloss black that I used over primer that had cured for more than a month.Good catch on the bullet connector and will save you from trying to catch a ghost later. Wow how high is your humidity? I normally only use rattle can but I don't think I have ever seen color change like that and I have lived in some humid climates.
