Got the gear back from
@esh21167 a little earlier because it's getting cold outside quick and wanted to get things in the frame. I didn't take as many pictures this time because it's just getting cold out.
Remove the crank holder, be mindful for the dowel pins, but they'll likely be stuck there anyways from all the oil. Remove the crank. Slide the new timing chain over it as well as the starter gear and new seal. Very important to not forget the new seal.
As discussed previously, line up the weights, then allow the the rear balancer to naturally rest and then I slide the slipper under it while making sure nothing moves. I did loosen the tensioner slightly because you may find the rear balancer just simply won't make it but will be very close. When you get this far I use the front 10mm bolt for the slipper to start bringing the chain up. You can't use the rear bolt yet because that's for the strainer.
Clean the plain bearing areas on the crank, the case, and the holder. Put assembly lube on all these pieces. Check your work with the balancer. I just leave the bolts sitting where they go to check, as long as it's flush.
Put it together, torque the 14mm bolts to 24-27 ft/lbs per the FSM. There is a sequence to this so make sure to check the FSM on this. I would torque in the pattern to about 15 ft/lbs, then to 27 ft/lbs. Do the 10mm bolts after this. Spin the crank a bit back and forth make sure it's not binding. It should not be if you cleaned, lubed, and torqued everything properly.
Don't forget that seal!
Before you put the oil strainer back on you have to replace the o-ring on it.
I loosen the front 10mm bolt for the slipper, then put the oil strainer on and get the slipper tightened. Then torque all 10mm bolts to about ~110 in/lbs.
Don't forget to replace the large double o-ring gasket thing.
Everything is on. Now organize your case bolts, be sure to leave a copy of the FSM laying out with the bolt lengths so you don't get confused. Make sure the cases are clean.
EDIT 11-03-2023: IF YOU FOLLOWED THIS BEFORE THIS DATE I APPLIED THE HONDABOND INCORRECTLY AND RE-DID IT. THE FOLLOWING IS HOW TO DO IT.
Take some Hondabond on your fingers and spread it on the bottom of the case.
Put the cases together. Watch to make sure things are aligning. They should because of the dowel pins. Put the bolts in, then start getting all the bolts finger tight. Then torque all 10mms to about 115 in/lbs working around to do it evenly. The 12mm bolt is 15-22 ft/lbs. Don't forget a new oil filter and tighten the drain plug with a new washer.
Flip it over, put towels in there to prevent dirt from falling into the crankcase. I put the front bracket on engine loosely to help align things. Put down a bunch of wood on your jack and get it in there. Get the bolts finger tight, leave the the engine still supported under the jack. Remove the front bracket temporarily so you can fish the starter wire and oil cooler wire through. Lube the new o-ring on the starter. Install the starter. Will be "fun" because of the new o-ring you installed on it. 2 bolts for the starter. I ended up using a rubber mallet, gently, to get it to go in. Add the front bracket back on, but leave it very loose, fish the starter wire through it.
For the oil pump add the new o-ring, grease it and bolt it up. 5 bolts total, two for the oil pressure sensor cover and three for the oil cooler itself. Now you can add the front bracket on, fish the sensor wire through the front bracket. Finally tighten then engine mount bolts. 14mms to 33-43 ft/lbs and 12mms to 15-22 ft/lbs.
Remove the jack. Double check your torque on the oil filter and oil drain bolt.
I spent time adding the stator/rotor, oil pump chain, kickstarter and gear shift stuff back on and connecting wires, but no pictures. Will get some later. So far everything is going well.
