That lower toolbox bolt is actually a long stud, threads sticking out on both sides to retain the air cleaner covers. Part # 90157222000 . A 6mm nut and flat washer on either side to retain the toolbox followed by a nut, flat washer and a lock washer to hold the tab on the air cleaner cover.Got a bit more work done. Engine in the frame, wheel bearings done, got the bars drilled to run the wires internally.
The frustration of the mismatches in the parts listings versus reality:
Listed as a 70mm. Likely actually a 60 - which would explain the SAE hardware that was in there before.
Had to put the tank on proper to check fit. Plus it’s always nice to see it start looking like a bike - instead of a pile of stuff that needs to be cleaned.
Onto the brakes, tires, and dealing with the headlight bulb missing a mounting tab.
Yeah, at $20+Shipping I went with a screw for now. There's a couple of things that if I wanted to push another $500 or so into the pot could make it a bit nicer. (New front fender, headlight trim ring, that bolt, etc.)That lower toolbox bolt is actually a long stud, threads sticking out on both sides to retain the air cleaner covers. Part # 90157222000 . A 6mm nut and flat washer on either side to retain the toolbox followed by a nut, flat washer and a lock washer to hold the tab on the air cleaner cover.
My thoughts exactly, I've been working on my drag bike project for over 6 years....Wow, looks really good and all this in only 4 months!
Now I know how much time I used to waste drinking!Wow, looks really good and all this in only 4 months!
Yeah. I added a couple since I needed to ground the rec/reg anyway. All voltages check out back to the negative battery terminal so there should be a clean path to ground (the leaky circuit does need to be checked out on both sides - waiting for the heater to do its thing right now before going back out there.Grounds all good everywhere, even the heavy ones like engine mounts?
I haven’t tried that. Just checked if it was getting 12+ at the post - that should be basically the equivalent? Well, unless there’s an amperage drop I guess. Time to rig up an 8ga jumper and see.Have you tried jumping the starter directly from the positive post on the battery to the connection on the starter with jumper cables or heavy wire? That should help eliminate if it is the negative or positive side that has a bad connection assuming the starter is working properly.
Welp. No dice on the jumper. Looks like the starter is coming out. I did manage to get a disdainful groan out of it after charging the battery to 13.3 - so I’m betting on brushes and internal contacts.I haven’t tried that. Just checked if it was getting 12+ at the post - that should be basically the equivalent? Well, unless there’s an amperage drop I guess. Time to rig up an 8ga jumper and see.
My bet is old dried out grease in the starter gearbox and bushings as well as dirty contacts. Be aware that you need a grade 2 grease for the starter and not too much at that.I did manage to get a disdainful groan out of it after charging the battery to 13.3 - so I’m betting on brushes and internal contacts
I had a 1966 CB160 that had a seized lower connecting rod bearing. I wanted to replace the bearing. The Honda Shop mechanic told me that getting the crank apart is hard enough but to reassemble it required a special jig that only the factory has. I have seen the crankshaft parts on CSML and wondered why they would sell something that the average guy cannot use.Looking good there Pete.
I did PM message Graham Curtis in England about the CL160 crankshaft and the internal sludge traps. He sent me a bunch of pictures and info on the CL160 crank. There are extensive sludge traps in there just like the other CB450 DOHC and CL77 cranks. As suspected you cannot clean the cranks without pressing them apart for a proper cleaning. It is beyond my skill level and you need at least a 5 ton press and some metal blocks to set up for the operation.
I feel I have got something fluid wise going through the journals to the conn rod big ends and hopefully it will suffice.![]()
There is a difference between shop procedure and how you can actually do things. Just look at "special tool # whatever" in every maintenance manual. To reassemble the multipiece crank, you need a press and a scheme to keep the counterweights and key way(s) aligned. This would require you to build your jig before you take it all apart.I had a 1966 CB160 that had a seized lower connecting rod bearing. I wanted to replace the bearing. The Honda Shop mechanic told me that getting the crank apart is hard enough but to reassemble it required a special jig that only the factory has. I have seen the crankshaft parts on CSML and wondered why they would sell something that the average guy cannot use.
Meant to answer this earlier. They’re apparently an aftermarket set from the late 70’s as far as I can tell. I know the bike was last on the road in 81 so that would track. There’s also (or was) some painted over damage from a lay down on the right side so I imagine they were replacements for this.Really nice work! Maybe you mentioned it earlier and I missed it, but I was curious what handlebars you've got on the bike?
My bad. I was talking about the ones on the red bike. The scrambler style from the orange bike I’ve just got shoved on the rack.Those scrambler bars are likely CL77 pieces, they weren't drilled for wires at the factory. The giveaway is the slightly larger diameter cross brace, on the CL77.
To NPN’s credit, they were very quick to acknowledge the mistake and correct it this morning. Sent them an email last night, had the shipping confirmation and the “whoops” email by 9AM.Ugh- that's a bummer. Hopefully they get that sorted asap...
That same yahoo shows up and works at my house pretty often!Turns out some yahoo completely missed the fact that the slow jet was completely obstructed and that the float pin wasn’t springing.
Man, that yahoo sure gets around!That same yahoo shows up and works at my house pretty often!![]()
Yeah - I need to have a chat with that guy - he put the slide in backwards on the carb as well.That same yahoo shows up and works at my house pretty often!![]()
Pete,Well. Oil leak solved by placing a washer between the crankcase and the starter mounting tab. Truly bizarre, so the EBay dig will commence for a replacement - something ain't right with this one.
Carbs on the other hand... May have been too far gone to be serviceable, I'll be giving them a very extended soak while I'm out of town the next couple of days, but it looks like an Ebay kind of week. Seems like these salvage projects always like to find one area to really fight you on.
Looks like the second round of cleaning got the right carb in line. It fires right away with no choke now (probably means I’m running a bit rich), both are sounding pretty good.Pete,
A little late here ........ yet Joe has a set of CB160 carbs I believe, as a parts set. The last time I saw them they were mostly compete IIRC. If you need some parts or bodies I can dig into it further. Joe will likely sell them cheap as they are and shipping would be semi costly around $50.00 I would think to Texas.
Did you put some Hondabond around the alternator wiring grommet in the cover? That's a usual spot when all the seals have been replaced, that grommet is probably hard as a brick at this age.Did have another oil leak pop its head up - somewhere between the left crankcase cover and the case. Looks like that cover is coming off again - seems to be fairly low but it leaks inside the front sprocket area.
That’s the first thing I thought of as well. It “feels” like the leak is below that point, but it’s the likely culprit. You’re right though, it’s essentially plastic and has probably shrunk so I’ll need a bit of a heavier layer there - it’s just hard to police what could get squeezed off into the interior side of that case there so I’m always a little tentative.Sounds pretty good, pipes sound nice too so they must be in good shape.
You have been bitten by a few garage gremlins lately. I have confidence you will prevail, this ain't your first rodeo.Went through both carbs again. Fired up - now with only the right cylinder.
Oh. And a fresh oil leak from the tappet cover.
This is all supposed to be a fun hobby, right?!
This is one that has me really perplexed. Probably time to start at the beginning, set timing, valves new plugs, set floats and start from scratch.You have been bitten by a few garage gremlins lately. I have confidence you will prevail, this ain't your first rodeo.
It is strange to be sure. And knowing you by this point, I'm sure you've already checked the usual and common possibilities. Battery voltage perhaps?This is one that has me really perplexed. Probably time to start at the beginning, set timing, valves new plugs, set floats and start from scratch.
Yeah. Thought battery yesterday and left it on the charger all night. Right cylinder fires instantly.It is strange to be sure. And knowing you by this point, I'm sure you've already checked the usual and common possibilities. Battery voltage perhaps?
And I know it wasn't at too high a rate that you cooked it.Yeah. Thought battery yesterday and left it on the charger all night.
Yes fun! But also provides many opportunities for ….critical thinking skills, meticulous execution , redoing the same thing four times, starring in disbelief, mumbling under breath, cursing out loud when alone and that’s just my short list!Went through both carbs again. Fired up - now with only the right cylinder.
Nah. It’s a trickle setup - at peak it can put out .3-.4 amps. Anything electrical would present on both cylinders with a single coil.And I know it wasn't at too high a rate that you cooked it.
Well, I'm not so sure it wouldn't affect the spark strength to both plugs despite it being a twin lead coil, I suppose it could make both weak or the "better" path to ground might get the lion's share of available voltage. But I haven't had a 360° crankshaft twin since 1971 either, so it's conjecture on my part.Anything electrical would present on both cylinders with a single coil.
Yeah. Running on the external tank bowl fills.Have you confirmed your getting good flow from the petcock and you don't have a sticking float or needle? I was having similar issue and swapping floats for old ones seemed to resolve it.
