I hate to say it but yes I think you should.I did clean the oil strainer and removed all the old debris. Do I need to disassemble and clean and reapply the Hondabond? I can if you think that it will be a problem.
I use a finger tip to literally smear it, you can see the surface thru portions of the smear. You're only looking at a couple thou thickness to get a good seal.Not a big deal. I have time this weekend and will revise the pictures. How do you apply it?
Honestly I've had it apart enough it's really not that scary like it was before.
Also, I meant to say WON'T be a problem!I hate to say it but yes I think you should.
Yes you are very fortunate there.Yeah the balancer system seems to be the most annoying part on the 400/450 twins. Would have been better to have access to the chain from a cover. But with the oil pump and primary gear there's not a lot of room. Lack of oil pan is unfortunate as well. This means you have to drop the bottom end to get access to that strainer.
I wouldn't quite say I'm at an hour, maybe 90 minutes.
I'm very fortunate that it wasn't catastrophic. Could have damaged or bent the rods.
Whew! All good news then.Back on the bench. Sorry did not flat rate time it. Bottom of the case was good, no debris. No metal shavings or any scary stuff going on. Easy to remove the Hondabond this time because it's only been a couple of days and was not excessive so wiped it all off with thinner in about 20 minutes.
I believe the chain comes tomorrow since DSS had one at their Hanover warehouse which is a stones throw from me.
Got the new chain, and was getting ready to install and I noticed I did the exact same thing! Since fixed, bolted it back together and in the frame. Good thing I have to go back in there! I'll update the original post about that.A little story on myself. First one of these I built I put the balancers in 180 degrees out. All back together and on the center stand. Rev up the rpm some and when I let off the throttle the bike hopped backwards on the center stand. Tom said I should make a vid of it and post it on U Tube. It was funny. Not funny was taking it back apart to repair it.
Bill H
Yes, it's a 360* crank so both pistons are TDC at the same moment.Machine work is officially done. Will be sending off the funds shortly.
Question for Jim, I believe for these engines the pistons are both at TDC at the same time due to the design of the engine being 360 degree crank? Rather, it's a matter of the mark on the camshaft during assembly and then setting the valves based on the lobes? I am aware that the best thing to do is remove the rocker adjustment screws to prevent trashing the valves during this delicate operation.
Hard to put a value on satisfaction and quality. Then again there's things money can't buy.Check sent to the machinist, should be receiving the parts in about 2 weeks.
For the curious, total cost of this rebuild, including the shipping ended up being about $3200.
Did you purchase that collector box NOS ?Starting to look like something again... I thought more about the superseded base gasket. I noticed those cut angles. I guess it would work either way so they simplified it.
Looks like, so far, the collector box fits correctly. Some small bit of wrestling to line the two bolts up, but not that bad.
No, that's the aftermarket one available from David Silver Spares.Did you purchase that collector box NOS ?
A quality Repro to match the specs of the original ?No, that's the aftermarket one available from David Silver Spares.
Fits fine, but one side for the heat shield has the screw slightly askew however barely makes it. The inside has some tubes, but I don't think curves are the same. It doesn't have actual paint, but some kind of powder-like coating used to protect it similar to cheap aftermarket body panels. This means you must remove it and prep it and paint with VHT exhaust paint. See previous page or two in this thread for the process and comparisons.A quality Repro to match the specs of the original ?
That's a myth. I worked on a cm400a that had sportster pipes welded and ran exactly the same as my stock cm400aLooking at the other posts helped.
I'm glad you were able to purchase a new(repro)power chamber;I hope it will give the same midrange power to your bike as the original had.
I have seen/spoken with many owners of 400/450 even CX500 models that have entirely removed the power chamber and run separate exhaust pipes,which I think takes away performance from the bikes.
LDR explained the purpose of the power chamber once, long ago in land far away, I'm not sure I really get it, but it's a Honda thing that does kind of seem to be like vestigial organ. That's why I call it the exhaust gizzard.That's a myth. I worked on a cm400a that had sportster pipes welded and ran exactly the same as my stock cm400a
Lol,I disagree.That's a myth. I worked on a cm400a that had sportster pipes welded and ran exactly the same as my stock cm400a
In reply to myself, it's worth mentioning I have not noticed any difference in performance with a later-era VB carb that has a fuel accelerator diaphragm versus the 78 and 79 (maybe 80?) years. Again, same test, same bikes. The only difference between them besides the diaphragm is that I did the "trick" of changing the main from 65 to a 68. May also be necessary if you defeat the fuel acclerator diaphragm but I have no idea and have never tried to do so. Could be an interesting project for someone.\Maybe other pipes, but the sportster pipes did nothing except change the exhaust note obviously. I personally did some runs from a stop up a large, steep hill near me on both bikes. They both reached the same speeds at the same points more or less. I didn't have it certified obviously, but if there was a difference we're talking margin of error difference only detectable on specialized equipment i.e. a dyno.
