RobMan
I have another question, what is the easiest way to remove the valve stem seals without damaging something? Online the replacements appear to be all one piece but I don't want muck anything up. Thanks
Once you remove the bolt and retainer 'fork' over the seal, you just have to get under the edge of the seal and pry it upwards. They basically "snap" over the end of the valve guide, then the fork keeps them from popping off. Just use something L-shaped that is thin enough to get under the edge of the seal outer diameter. For a lot of little things like this, I use what is often called a "cotter pin puller"I have another question, what is the easiest way to remove the valve stem seals without damaging something? Online the replacements appear to be all one piece but I don't want muck anything up. Thanks
Thanks the reassurance and that is what I assumed but it seemed a little stubborn so I wanted to double check.Once you remove the bolt and retainer 'fork' over the seal, you just have to get under the edge of the seal and pry it upwards. They basically "snap" over the end of the valve guide, then the fork keeps them from popping off. Just use something L-shaped that is thin enough to get under the edge of the seal outer diameter. For a lot of little things like this, I use what is often called a "cotter pin puller"
I am sure I will probably get a new chain but it seemed odd to me that Honda does not seem to provide any wear specs. I suppose they figure that anyone rebuilding an engine would just change it for as you say peace of mind. ThanksOthers will probably have better advice about the cam chain, but when I replaced mine several years ago, it was tight enough that I had a pretty hard time getting the master link in. I was relatively inexperienced at the time, but I would say if it seems easy to slip a new master link into place that the chain has stretched some and it may be worth replacing. Plus if it's the original chain and there's a lot of miles on the clock, why not replace it for peace of mind. The "original" chain in my bike had more than one master link and that was my sign to replace!
You might look at cmsnl.com for pistons and ring sets to compare prices. They seem to have OEM and at least one non-OEM option. I used Honda +0.5mm pistons with my rebuild and purchased them on eBay.
Thank you for the link for a new chain. They seem to be a hard find just Googleing to find a DID 219T chain although I did find one on ebay for about $65.00 that appeared to be in the correct packaging but the vendor you recommend would be cheaper as well as being vouched for . I have already ordered a new master link from 4into1 when I ordered a gasket and seal set and will probably order another one later as I am sure I will need to order other stuff.Since I saw no mention of how many miles are on the bike in the early part of this thread, combined with some of the sketchy work that seems to have been done on it, I absolutely agree with replacing the cam chain. And the best place to get one is here -
Honda CB 450K CL 450 Timing Chain D.I.D. 219T128 with lock timing cam chain | eBay
Find many great new & used options and get the best deals for Honda CB 450K CL 450 Timing Chain D.I.D. 219T128 with lock timing cam chain at the best online prices at eBay! Free shipping for many products!www.ebay.com
I believe his chains come with a pressed side plate master link, which I personally have never felt comfortable with so I buy DID rivet type master links from 4into1, get a couple in case you have to break the chain again before the engine is finished and in the frame
Genuine Honda - D.I.D Cam Chain Master Link - 219T - Rivet Type - CA/CB/CL72/77 CB/CL/350K/450K SL350K CB500K/550/750
Genuine Honda D.I.D cam chain rivit type master link for 219T type chain. This master link will only fit with 219T D.I.D brand chain which was the original (OEM) cam chain used on the models below.4into1.com
I did skim through the FSM and two other manuals (Chilton's and Clymer) — I didn't find anything, either. I wonder if this is because the designers didn't anticipate the lifespan that these machines would have.I am sure I will probably get a new chain but it seemed odd to me that Honda does not seem to provide any wear specs.
This is the main reason, the unknown. And the prior maintenance it (may have) had, as well as the prior rebuild. Your donor engine is a great example of the lack of good maintenance as well as the wear and tear on the chain because of it. Good that you checked the tensioner assembly for proper operation too.The engine I am rebuilding had 33000 miles on the clock and I know it was worked on extensively at least once. No telling if the cam chain was changed or not of course.
They don't really provide any specific wear specs for the drive (rear) chain either. Just as the FSMs in our library were designed with the dealership mechanic in mind, not the public, a good mechanic would make a judgment call on the cam chain based on long term reliability. From my perspective, it's all about never having to go back in there again as long as you own it....but it seemed odd to me that Honda does not seem to provide any wear specs.
I wish NC made it bit simpler. With having to pay for appraisals and buy an Indemnity bond it adds an unexpected expense which doesn't count the DMV fees themselves.It keeps surprising me that California, the State everyone loves to hate for its rules and regulations, hardly gives a crap about no Title. They look in their records and if the bike is in there with the right owner and plate numbers that's enough. They might charge you some crazy fees if it wasn't put on non-operational, but you'll get your title in the mail. If the bike has fallen off the system (after 7 or 10 years of no records at all it vanishes) they run the VIN through some national database and if it's clear you get a title. And they ask you to fill out a form where you swear to the price you report paying and they tax you on that value.
Yes that does sound like the next step if the Kroil does not work. I already have the bearing cap off the other side of the cam so I can lift it up about an 1/8 of an inch to get something under the backing plate to hold it up when I try to give it good wack and see if I can get it to come loose. Thanks for the suggestion.I was going to suggest loosening the cam bearing on the opposite side by about 5mm, apply some heat to the advancer and then give the points end of the camshaft a sharp wrap with a flat ended punch with a 10mm diameter (see the circled area in red below). Unfortunately the points advancer has a shoulder on the back side that is 22mm in diameter, and only covers the 'soft' edge of the oil seal underneath. If you wanted to give it a wrap, you will have to put something under the advancer to keep it locked in place.
View attachment 31037 View attachment 31038 View attachment 31039
It's been @10 years since I left CA but last I knew of the Non-Op had a renewal and small fee yearly. The PO of the roadbike never kept it up so there was money due at DMV when I registered it.That title issue can be sticky. If it was stolen 30 years ago it's never going to be yours, and that owner doesn't owe you a cent. We can register a bike non-operational, pay once and not again until you decide to put it on the road legally.
I will be sure to ask that question when I go to the DMV just to make sure there are no surprises. Interesting thing with NC DMV is some fees are cash only and some can be paid with a card so you end up using the handy ATM machine they have in the office for the cash only ones.It's been @10 years since I left CA but last I knew of the Non-Op had a renewal and small fee yearly. The PO of the roadbike never kept it up so there was money due at DMV when I registered it.
Sounding like home where I grew up in southeast Oklahoma. Too many darn rules and regulations!I just keep one plate and rotate. Nobody ever checks a VIN on an old MC around here.
I’ve even done it on autos. Back when I had two almost identical C-10’s I made duplicate VIN plates - everything else was so modified only that VIN plate was left in each.
They're aluminum, lightly polished and clear coated from the factory, which is what the yellow color is likely from.Question, what material is the cam bearing caps made out of? When I was cleaning the caps I noticed there was a gold tint coming through the aluminum so wondering if they are in fact plated brass or if they have some brass inserts forged in them?
Yes that is my opinion as well although I have to admit to some disappointment.The seat with the pitting needs to be ground, it'll only get worse.
It’s really tough to find a machinist that has the proper dies, a decent knowledge of these engines and actual willingness to do a small job.I have seen some chatter from @ancientdad and others about the care that needs to be taken by the machinist when grinding the valves and seats. I have also seen that the valve stem tip needs to be ground down if the valve seat is ground. Is this correct and if so is there any documentation? I looked in the FSM but didn't see any mention of it and I want to make sure the person doing the valve job has all the right info.
Finding a machinist with some bike engine experience is almost mandatory now. Cutting valve seats is a precision task and you might have to tip the valves afterward depending on how much was cut from the seat, but you do NOT get the valves ground. They're not like car valves, they have a thin coating of stellite (about .010") and can be ground through very easily so lapping is all you can do with them. As Jim always says, if the seats are cut correctly (and if you use new valves) you don't have to lap them.I have seen some chatter from @ancientdad and others about the care that needs to be taken by the machinist when grinding the valves and seats. I have also seen that the valve stem tip needs to be ground down if the valve seat is ground. Is this correct and if so is there any documentation? I looked in the FSM but didn't see any mention of it and I want to make sure the person doing the valve job has all the right info.
And fortunately that can be determined once the head is assembled because of the design of the 450 head, so the top end of the engine doesn't have to be fully assembled to find out....but you won’t know until you try to adjust the valves.
Very true. If you've got a good machinist close by you can start with just the seat and progress - I sent everything out at once because I could only find one place remotely near me and really didn't feel like trickling in small jobs, since those get pushed to the back of the bench all the time.! Luckily for Rob here, he's in NC which probably has as many engine machinists per capita as the inland empire in CA.And fortunately that can be determined once the head is assembled because of the design of the 450 head, so the top end of the engine doesn't have to be fully assembled to find out.
Thanks for the info but am not seeing a the name of the machine shop or a link. Hopefully the guy I am planning on using will work out as he is just a few miles down the road.Very true. If you've got a good machinist close by you can start with just the seat and progress - I sent everything out at once because I could only find one place remotely near me and really didn't feel like trickling in small jobs, since those get pushed to the back of the bench all the time.! Luckily for Rob here, he's in NC which probably has as many engine machinists per capita as the inland empire in CA.
If you do get stumped, here's who I used, they've got the stuff for CB450's. Definitely not cheap, but their turnaround time was remarkably quick for that world (<2 weeks from the time it left my house to arriving back)
If you can't find anyone locally you feel you can trust, you could send the head to Schumann Motor Works. He does excellent work but he's in Milwaukie Oregon - https://www.facebook.com/p/Schumann-Motor-Works-100054197273586/Thanks for the info but am not seeing a the name of the machine shop or a link. Hopefully the guy I am planning on using will work out as he is just a few miles down the road.
Thank you! I had to look up Cleburne, Texas to see where it at as I grew up in southeast Oklahoma so ranged down into North Texas some but don't think I ever went through there. I was also stationed at Bergstrom AFB (now closed) in Austin 2 different times so familiar with Texas but it is a big state.Corrected it.
Thank you! I am hoping I don't have to resort to sending parts off but it is good to have options.If you can't find anyone locally you feel you can trust, you could send the head to Schumann Motor Works. He does excellent work but he's in Milwaukie Oregon - https://www.facebook.com/p/Schumann-Motor-Works-100054197273586/
He did the head for my drag bike project and custom made titanium valves as well.
If you got real lost getting from one to the other, you'd end up in Cleburne! If you ever do get back down to Austin, the change will blow you away, Bergstrom is now the airport and the airport is now a multi-million dollar faux "live/walk" canned subdivision.Thank you! I had to look up Cleburne, Texas to see where it at as I grew up in southeast Oklahoma so ranged down into North Texas some but don't think I ever went through there. I was also stationed at Bergstrom AFB (now closed) in Austin 2 different times so familiar with Texas but it is a big state.
I was stationed in Austin for the first time in 1976 so had the opportunity of enjoying Austin as a young man when it was cool. Armadillo World Headquarters was still open as well as a lot of other cool clubs. Heck I may have bumped into Wayland and Willie and never knew it.If you got real lost getting from one to the other, you'd end up in Cleburne! If you ever do get back down to Austin, the change will blow you away, Bergstrom is now the airport and the airport is now a multi-million dollar faux "live/walk" canned subdivision.
Anyway, let's hope your local guy can do it - since you've got two heads maybe have him do one first and then the other?
Yeah, have him do the one with the chipped valve guide and ask him his opinion on the guide's usability when he sees it. Since many have cut off the ends of the guides during porting the head, he might tell you it isn't a very big deal.I might have him try his hand on the worst of the two heads first just to see his skill and to let him have a chance to make any mistakes on it if there are any.
You'll notice the entire combustion chamber is a steel "skull" pressed into the head, it's all one piece. On earlier 450s and many of the other Honda engines the seats are pressed into the aluminum combustion chamber.I wondering are the valve seats in the heads replaceable?
That is good to hear about the valve guide. I had wondered if it would make that much difference in operation but I also wondered what would have caused it to break like that. If I were going to use that head I think I would have a new guide pressed in if they are still available.Yeah, have him do the one with the chipped valve guide and ask him his opinion on the guide's usability when he sees it. Since many have cut off the ends of the guides during porting the head, he might tell you it isn't a very big deal.
