It runs (after a fashion)!
So the CB200 is more or less back together. There is some good news, and some not so good:
First of all, it started up on the key pretty easily, and it runs:
The CB200 runs (after a fashion)…
It needs quite a bit of fettling and some faults sorting out, but it is nearly there. One piece of really good news is that the oil supply to the cylinder head is very healthy. I used Richard’s suggested method of slackening the rear right cylinder head nut a few turns when I first ran the engine and was rewarded with a copious supply of oil. I have tightened the bolt, but must remember to re-torque it tomorrow.
Some not so good things: the silencers (mufflers) are rubbish, I have a new set of replicas that I’ll fit and should both quieten the engine and allow the kickstart to be used. An exhaust question if I may, the gasket kit came with these copper crush washers (presumably for the exhaust ports):
There were none fitted previously and they don’t seem to be mentioned in the manual, so I didn’t fit them today. Should I have fitted them?
Next the tachometer cable doesn’t fit into the drive properly (although the worm drive does work). It looks like it was held in with a lump of glue or sealant previously. I can’t find a good diagram in the manual, is there something missing or do I have the wrong cable?
The motor needs quite a bit of fettling: checking the tappet clearances and ignition timing (I did them both on the bench but things have probably moved around a bit since then), the correct exhausts fitting and the carburettors need to be tuned and balanced. I can’t find much information regarding carburettor tuning in the manual - can anyone recommend good start positions for the main and slow running screws?
The wiring is a bit messy in places (lots of domestic connectors and so on); I’ll go through that in slow time and get everything back to standard. There are some faults also: the horn button doesn’t work and the rear lamp stays on all the time (may be the brake light switch, I have not investigated yet).
There will probably be lots of other flaws… inevitably with a nearly 50 year old machine that hasn’t been used for about 20 years, but I’m fairly pleased that I’ve got it back together, it runs (more or less) and the lubrication system seems to be very healthy.
I‘ve left the battery charging overnight; now I’ve got to this stage (where I’d hoped to be 2 weeks ago when I bought the motorcycle) I can tinker with it until I get it sorted.
