Wednesday, and a pass-out to the garage for the day.
Starter hub/gear/rollers arrived early today, so that went on and really works well! Never had a starter on this bike that locks on and just keeps on cranking round. Fabulous!
Tried the idea from Sprint to put a few drops of fuel into the intakes but nothing. Put some fuel directly into the plug holes, but nothing.
Decided to fit one Chinese carb on the RHS. It spluttered into life! but really not happy, but it fired.
Getting excited, put the stock carb on the RHS (nothing on the left). A few seconds on the starter on choke it ran, and ran really sweetly. Exhausrt got hot really quickly too, took me by surprise as I grabbed the silencer to 'test' it...ouch.
Getting more excited I put the stock LHS carb on but only fuel to it, the RHS would be left to run dry. This was to be sure the LHS was working in it's own right, not assisted by the RHS.
IT RAN!
Once I had sworn at it I left it to run (2K on the tacho). RHS hot, LHS about 2/3rds as hot. Real progress.
Did a rough carb balance so the slide screws were at the same spot and eased the engine speed down 1/4 turn at a time on the RHS carb and the heat came into the LHS AND equalized to the RHS (careful touch of hand through gloves).
Throttle response is immediate and no bogging-down when you snatch the twist grip wide open, very keen to rev, and dies to the fast tick over quite quickly, about as fast as a normal car engine does.
First time it has behaved in this manner, ever.
It then petered out, ran out of fuel!
Decided to leave it there for the day, tidy all the odds n sods on the wires etc.
So, tomorrow I hope for more time to tweek the engine with the filters on and try to fix the oil leak on the cylinder head stud where the hot oil is getting past the washer and the domed nut and running down to the top front engine mount point. I hope a good clean and some HondaBond will seal it.
Can't have a Honda with a leak.
WHAT A DAY, 10 STEPS FORWARD IT FEELS LIKE, SPANNERS CROSSED FOR MORE FINE PROGRESS TOMORROW.
WILL I GET TO 1400 RPM? I DON'T TRUST THE TACHO, SO WILL EASE IT DOWN TO AS LOW AS I CAN GO RELIABLY.
