Indeed, and today was just like that, slow n easy, but progress.
I felt this was going to go well when the last wrist pin clip popped into place in a few seconds, now, that never happens to me, but did today.
After a bit of an effort because the rings now are tighter in the nice bores the cylinder block slipped down to the case with a bit of pressure, A few revolutions of the crank proved the movement to be really nice, so set the crank to TDC.
With the help of the wife to hold the cam chain tight and upright, the head went on.
And then came off.
The text in the Haynes manual forgets the 2 O rings on top of the block, so with them now in place the head was slipped down and the chain positioned TDC and 'O' on the cam gear @ 12 noon. The link clicked into place satisfyingly.
Released the chain tensioner and rotated the crank a few times, all baby-bum-smooth.
Assembly lube all over the cam lobes and the head on and progressively torqued to 13 lbft. Checked the timing AGAIN, and satisfied with the work.
With the engine still on the stand did the tappets. The small square screw head is a pain to turn and hold with a small adjustable spanner, so in a rare moment of inspiration found a Schuco tin plate toy wind up key has the very same square hole and makes a perfect adjuster/holder/and gives great access for the 8mm a/f spanner to nip the nuts up!
One of my other interests are post war Schuco racing cars and you can buy these keys for £3.
The car in the picture below I was given as a Xmas present 60 years ago, mega played with and a very cherished possession.
Put oil all over the tappets and put the covers on.
While on a roll, dropped the engine back into the frame! The thing just went in, all the mounting bolts slipped in (!) and tightened everything up. Wow, what a morning, even remembered to fit the earth ground cable too!
Hope to finish all the outer bits tomorrow.
