Denny K
Back to the project over the past couple of days. Installed the tail light assembly, surprised to figure out that the light is a compression fitting; seems a bit shaky to me, but for now it's good. Also put the headlight in place, all with the idea of installing the battery and hopefully seeing the lights come on when I turned the key. No such luck. Went back into the headlight bucket and checked the ignition switch connection. Since everything plugs in, it all looked good. Went to the electrical posts on the forum which caused me to take a look at the fuse box. It looks okay, and the fuses are the ones that have been living in this bike since forever; however they all look good. I pulled the battery and checked the light bulbs and headlight. They all work. I did not remove the ignition switch; it could be the problem, but I wonder if there are other things I am overlooking. Thanks for checking out my post.
