Denny K
Folks,
Recently picked up a 1979 CB400TI. This model as you can see has the spoke wheels, front drum brake and is kick start only. I have downloaded The Basic Checklist and Shop Manual for this bike. In addition, the owner’s manual was on board in the compartment under the seat and it is in good condition. I have removed the seat and tank and am figuring out what I need to do to get the engine started. A few years ago, I restored a 1974 Honda CB750K with a little help from my friends. Took it down to bare frame, put in new rings and did a top end so I do have some experience and am looking forward to seeing how this bike turns out.
I would like to ask a few questions to be sure I get started in the right direction. I have spent several hours perusing the VHT Forum and looking at threads of interest; hopefully I won’t be asking too many questions that have already been answered.
Keys – I have no keys and the guys at the Honda shop told me to locate the key code; they will get me fixed up. I bought the bike from them and they told me they would take care it. I have poked around but have not found it. I have not taken the instrument cluster apart. Bottom line, if I need to, I will pull the ignition switch and take it to a locksmith. However, if someone knows where the key code is on this bike that would be very helpful.
Seat – I am inclined to buy a new seat rather than get this old one rebuilt. I like the stock look and wonder what sources folks might suggest. I saw Texavina seats that looked nice and of course there are plenty of other vendors.
Rear Passenger bar and turn signals – This item did not make it. I have seen some for sale on eBay. Will go that way, but would rather buy things from Forum members if available.
Rear Tail Light – The large hard plastic socket holder is broken. Am looking for that, hacks to fix the one I have, or cool substitutes.
Case Pilot Upper – Areas around the instruments are broken out and am looking for that part or other suggestions.
The coil case is cracked and the plug caps are in bad shape, I plan to replace all that and get new plugs. Need to get a battery. The tank needs to be cleaned, but I do have a temp fuel tank I used for balancing carbs. Will do a cold compression test on the engine before trying to start it.
I have standard motorcycle jack but wondered about using that jack on this bike because of the pre-chamber unit. Don’t want to damage that. Any suggestions on using the jack?
Thanks, and all comments are appreciated. Not sure how the pic will turn out, need to review how to post pics. Sorry
