Looks good, other than the circlip for the shift shaft which looks a bit too expanded - is it fully in the groove in the shift shaft? Did you put the circlip on so the totally flat side is facing outward as well?
New circlip from DSS and the clip is all the way in the groove and I double/triple checked to make sure the flat side is facing out. With my eyes even with a magnify glass it was bit hard to tell and then every time I handled it before I put it on I was afraid I had flipped it so had to recheck again.Looks good, other than the circlip for the shift shaft which looks a bit too expanded - is it fully in the groove in the shift shaft? Did you put the circlip on so the totally flat side is facing outward as well?
The end play sounds right, but the clip looks stretched open a bit, that's all. If you can push it by one tang and it rotates in the groove then it's seated, I'm just always concerned that they fit snugly on the shaft.New circlip from DSS and the clip is all the way in the groove and I double/triple checked to make sure the flat side is facing out. With my eyes even with a magnify glass it was bit hard to tell and then every time I handled it before I put it on I was afraid I had flipped it so had to recheck again.I am able to just shift the spindle back and forth a few thousandths and it appears to be locked in well.
Good catch on the verbiage, I should have said neutral light switch.By neutral safety you mean the indicator, right?
Or did you rig in the late 70’s-80’s interlock that prevents starting without being in neutral?
No I can not see myself making my life more complicated and I am not a big fan of how industry has to add yet another safety device on something simple because an idiot managed to injure or kill themselves. My favorite example is the new gas cans which require at least 2 people to add fuel to a lawn mower or a new car, one to lift and lift and hold the can and one to operate/over ride the safety mechanisms.Good. I was hoping you hadn’t got a wild hair for some reason and over complicated the ignition circuit. I got sick of it on mine and just bypassed it.
Yes, the world has been compensating for stupid people for far too long. I hear you about modern fuel cans, I just added a 5 gallon can to my group and even though it has one of the better spout designs, the handles are not properly designed for ease of use while fiddling with the ridiculous valve opening method.My favorite example is the new gas cans which require at least 2 people to add fuel to a lawn mower or a new car, one to lift and lift and hold the can and one to operate/over ride the safety mechanisms.
Thanks I did do that after I took the photo but a reminder is always good. WE got well trained in the Air Force on taking care of our precision tools especially if we dropped one and it had to go back to have the calibration checked.Always return the torque setting of the torque wrench to the lowest torque after usage![]()
That is what my gut was telling me but I hate to mess with something if there is no need. ThanksYeah, I might take the 3 that are right at .012" and open them up to .014" or .015" to be safe, considering the upper limit is .031" you'll be fine.
I went back and looked again, and it even chipped the edge of the lower front screw hole in the lower case. I once saw a clutch rod that was hit hard enough that it also cracked the steel mainshaft small end bearing where the hole is for the clutch rod, knocked a chunk out of it.I looked at the photo of the open side to see what @ancientdad was talking about with the clip, and I was impressed with how many scars there are from a broken chain. I had a bike that felt like the clutch was sticking some and it turned out to be the clutch release rod was slightly bent from getting whacked by a broken chain. While yours is open I'd take out the push rod and just roll it across some known flat surface to check it.
I am not sure if that was the chain or the PO as the threads are stripped about a1/4 inch in the broken area of the hole but there is quite a bit of good thread further down so may have to use a little longer screw then what it calls for but should be OK. I will double check the clutch rod as well.I went back and looked again, and it even chipped the edge of the lower front screw hole in the lower case. I once saw a clutch rod that was hit hard enough that it also cracked the steel mainshaft small end bearing where the hole is for the clutch rod, knocked a chunk out of it.
My concern was that the tips of the circlip looked to be a bit wider apart than what you'd expect if it was fully seated, as if maybe the tips got spread apart a bit during installation. They're a bit difficult to handle while moving across a long shaft like that (particularly if your circlip pliers aren't perfectly suited) and it isn't hard to over-expand them. If it passes the test of staying fully in the groove, then you'll be fine.I couldn't stand it so I went to the garage last night and checked the circlip on the spindle and confirmed it is locked well and good in the groove on the spindle and I can push it around by a tang with quite a bit of force. I also got out the 2nd spindle I have and compared the old circlip with an extra new one I had purchased from DSS and the tangs look a bit larger on the new one and the fit on the spindle is the same as the spindle installed in the engine. I also took my hard plastic mallet and gave the spindle a few light whacks on the end just to test the clip to see if would push loose and it held in place. I think @jensen's suggestion of an E-Clip is certainly worth considering especially in stainless. I have had to remove and install them without any type of special tool and they are a bear. With any knock or impact that would dislodge an e clip you probably bigger problems.![]()
It was a new one to me as well and I kept looking for another explanation like something in the groove keeping the clip from seating.I'm one to always double and triple check wristpin clips, too much at risk there not to. Can't say I've ever gotten any clips that were so long they overlapped though.
Good catch on that. I will have to take a look at it tomorrow and see if I see that gap there. I ordered a couple of new clips as well as a couple of shift spindle circlips from Partzilla so hopefully I can resolve my clip issues. Is clipitis a thing?
I tried to shift the clip that was overlapping a bit but couldn't get it to move and really didn't try too hard because I didn't want the tool to slip and gouge the piston. About to call it a night but will take a look tomorrow.Are you able to rotate the clip at all?
Certainly a possibility although I only used my fingers to install and tried to only use enough pressure jut to get the clip in place. Hopefully the new ones will do the trick I can get the cylinders and head installed.Honestly, it looks like that one just got bent slightly oval, which would explain both the not quite seated in the groove and the overlapping ends. It happens.
AQL (Acceptable Quality Level) for most hard good manufacturing has a Critical Defect rate of about 2.5%, not to mention shipping and storage and who knows how many hands those things passed through on their way to you. When it comes to little stuff like this and master links and fasteners I always try to order at least 2 extras for this reason. It has led to a rather large disorganized tray carefully labeled "Random/Weird Stuff" that sits in the parts cabinet until it fills up, then sorted and boxed, forgotten about and reordered again a couple years later.Certainly a possibility although I only used my fingers to install and tried to only use enough pressure jut to get the clip in place. Hopefully the new ones will do the trick I can get the cylinders and head installed.
I know what you mean on buying extra stuff, I typically find the small part that I knew I had but can't find shortly after buying another one.AQL (Acceptable Quality Level) for most hard good manufacturing has a Critical Defect rate of about 2.5%, not to mention shipping and storage and who knows how many hands those things passed through on their way to you. When it comes to little stuff like this and master links and fasteners I always try to order at least 2 extras for this reason. It has led to a rather large disorganized tray carefully labeled "Random/Weird Stuff" that sits in the parts cabinet until it fills up, then sorted and boxed, forgotten about and reordered again a couple years later.
In my experience, the narrow area of the head gasket at the front and rear of the cam chain tunnel needs a thin smear of sealer. I've always used silicone sealer modestly, but Hondabond is fine there too. And it can't hurt to put a little on the head gasket around (but not too close to) the flat o-rings where the oil flow goes up the two right hand cylinder studs. I do this on both sides of the gasket in both areas, but again, not too close to the openings for the flat o-rings for obvious reasons. On my red 450, I also used Hondabond on the base gasket just as insurance, though I've never had any sealing issues there personally.but I am wondering if there are any areas I should consider using a bit of gasket sealant on that are know know to be problematic.
Honestly sometimes I feel like I am moving slower than a glacier until I remember something I almost forgot or did forget and have to redo a step.Slow and steady now, double check everything. You're doing stuff you don't want to have to do again. I kept stopping and walking away, thinking it through and looking for things I had to do that I might forget. There was a pad on my workbench where I could scribble down notes to remember one thing or another. Since the engine I am working on is still not running there's no way to know if I overlooked something anyway.
It's the beauty of retirement, it allows you to take the time necessary.Honestly sometimes I feel like I am moving slower than a glacier until I remember something I almost forgot or did forget and have to redo a step.
Thank you and that is what I thought I should do on the seals but wanted to make sure. I am planning on using Hondabond where you have indicated.Yes, some of the flat o-ring should stick up inside that hole in the head gasket. I've had to open up some head gasket knock pin holes too, comes with the aftermarket territory unfortunately. I like to leave the flat o-ring up slightly on the knock pin, then slip the gasket over it (once the holes in the gasket are large enough to freely fit) so a little of the o-ring protrudes out of the top of the gasket so you know it will contact the head surface and get compressed properly inside the gasket opening. I smear the Hondabond around the holes in the gasket leaving about a 1/4" of space between the sealer and the hole so it can't spooge its way into the opening. And don't forget the narrow areas across the front and rear of the cam chain tunnel. (obviously the gasket picture is flipped left to right)
Thanks for looking but I believe it is just camera angle and the gasket was not fully seated when I took that photo but I will take an extra look when I get to work on it.Is that just camera angle that is making the fire ring look like it's protruding into the cylinder?
