RobMan
Just be sure to work the hole full of grease using a toothpick or something. Obviously only works on blind holes and then be sure to clean all the grease out if you are going to need to thread a bolt in later.
My '71 CB is the same as your '71CL, with the spline only on the one side. Not sure why Honda changed their manufacturing technique in '72, maybe more symmetrical=better balance?the 71 CL is splined on one side but smooth on the other. I am assuming just a difference in manufacturing but wanted to ask about it.
Probably just a different company got the contract to make the crankshafts and they did it slightly differently. I really didn't see it as a problem but it caught my attention.My '71 CB is the same as your '71CL, with the spline only on the one side. Not sure why Honda changed their manufacturing technique in '72, maybe more symmetrical=better balance?
Different engineer drawing up the prints but same result. The one on the right looks more elegant.I suspect that some of the manufacturing changes are simply revisions to lower cost and or simplify the manufacturing process. I noticed a revision on the primary gear when I had K5 (right) and K7 (left) motors apart at the same time.
The older, more complicated spacer on the right was replaced by a special flat washer on the right and the gear was made wider to compensate. Notice that the extra part of the gear does not seem to get used (no wear).
At least these questions don’t make you shake your head in disbelief like when you see something a P.O. has done to some defenseless motorcycle.Extra steel on the gear is cheaper than the bronze thrust washer? We need answers for these 50 year old questions.
If I had a dime for every time I shake my head in disbelief, I'd have enough to pay the chiropractor to keep me able to take care of myself.At least these questions don’t make you shake your head in disbelief like when you see something a P.O. has done to some defenseless motorcycle.
Thanks and will do. I really appreciate the advice.The only seal I'd put some Hondabond on would be the clutch rod seal, none of the others are a problem keeping them in the crankcase. I wouldn't add any "extra" anywhere in particular, a thin smear on one half of the crankcase is enough because Honda's machining tolerances were so good they fit together quite tightly. Glad you got the gears sorted, yes it's easy to slip one on backwards.
Yeah NOS Parts Now on ebay has some but they are redicuouly expensive. I may have try the hardware stores and try to mix and match from different vendors.That's rotten luck. It looks like CMS ought to have most of them. I looked at Partzilla and they had some, but not all. Both schematics skip #8, which appears to be a bolt. Those may be more expensive options, though.
That's exactly what my late grandmother used to say when she realized she had to rip out days of needlepoint progress and start over. ("I was just practicing")OK that time was just practice.
I know I should have replaced the bolts as I have had this problem before with my first 1972 or 73 CB450 back in 1977/78 when I was in the Air Force. One of the case bolts broke off exactly the same way so I took it to the local Honda shop in Victorville California to get repaired, instead they messed it up worse. Then I took it to a friend in the machine shop on base and he drilled it out, tapped it and put a length of all thread in it so I just used a nut where the bolt head used to be. Not elegant but it worked.Yes, typical a (earlier) over-torque pattern on the stuck end of the bolt.....
I am sure your Grandmother was holding in some "frustration" when she said that because Drat was not the word that came out of my mouth. I appreciate the offer to look and I will keep it in mind but hold off for now as I am going to try to replace the 6mm bolts with new ones at least. I think the 8mm ones will be OK.That's exactly what my late grandmother used to say when she realized she had to rip out days of needlepoint progress and start over. ("I was just practicing")
Two steps forward, one step back. Good save on the bolt extraction though. I was thinking that the bolt visual wouldn't matter because it's underneath, but of course it has to be one of the front ones where the head of it can easily be seen... I probably have a good one somewhere in the pile of spares I have between my 2 spare 5 speed bottom ends, but finding it for you would take a minute or two. Happy to look if you want.
Yeah, "drat" or maybe "dagnabbit" was probably about it, she was pretty low-key.I am sure your Grandmother was holding in some "frustration" when she said that because Drat was not the word that came out of my mouth. I appreciate the offer to look and I will keep it in mind but hold off for now as I am going to try to replace the 6mm bolts with new ones at least. I think the 8mm ones will be OK.
I know what you mean. I never heard my grandmother say a curse word in spite of everything I did which should have made her eligible for sainthood for not throttling me. Of course she had the look and that was enough to make me behave.Yeah, "drat" or maybe "dagnabbit" was probably about it, she was pretty low-key.
I hope so cause I really don't want to have another practice session. Thankfully I believe I have all new screws for the covers so hopefully no troubles there. I guess I can take the time to cleanup the garage and organize parts I plan on using and those that are extra.Hopefully that scavenger hunt will be worth the effort.
Not really that bad, at least I was able to run the broken part of the bolt back out of the hole with a left hand bit without drilling or putting in a Helicoil. Also the Hondabond 4 had not cured that much so was easy to clean up with brake cleaner. Looks like I have all new bolts sourced so hopefully will go well. The 80 mm and 90 mm bolts are available from Home Depot and are inexpensive so perhaps worthwhile getting them at least if they are available in Canada.That's a shame you got that far only to have a bolt snap on you. Very discouraging. I will be closing my cases shortly, hope I don't run into the same problems.
Hope you find all of the necessary hardware.
Sorry I should have said they are only available on line here but with free shipping. Let me know if you want and I can order and mail for you.Can't say that I've seen too much selection at my local Home Depot aside from 6mm washers and nuts. I will check it out though, as spares are always good to have.
Thanks for the offer. I will scout out some local places to see what they have. If I come up empty I may take you up on your offer.Sorry I should have said they are only available on line here but with free shipping. Let me know if you want and I can order and mail for you.
Yep. Good call on the replacement the “good” one of the older bolts appears to have one foot hovering above the grave as well.You can see the threads stretched on the one that failed. I look for that and if it's stretched, it's junk.
Happy to share the vendor but I think it was more chance than anything that he had these bolts, Mostly a book seller with some random Honda parts and a parted out CB160.Yep. Good call on the replacement the “good” one of the older bolts appears to have one foot hovering above the grave as well.
@RobMan care to share that eBay vendor? Some of those weird bolts are needles in a haystack, and haystack hunts on eBay for me usually end up with more projects.
