RobMan
A ton of work has paid off and looks awesome! Enjoy the moment.
The left carb has an occasional drip from the overflow tube
The carbs were sitting a while after being rebuilt, so I'm not too surprised by the imperfect float valve. This will give me a chance to verify float height and see how clean the carbs are after some fuel flow from the tank.It's always something! Getting the carbs and ignition tuned in is tedious, and Honda didn't make it easy.
Agreed. There are always little things that pop up, even after a vintage bike is fully tuned and broken in, so this is about par for the course.If the worst you noticed on the maiden ride was this then hopefully bodes well for the future.
Definitely. I think I'm going to smear some two-part epoxy over the corroded areas inside the bowl. I'll try to fill the hole without coating the entire bottom of the bowl. The replacement bowl will serve as a backup for now.Too much corrosion for too long.
Is it possible the o-ring on that lower rotor cover screw is old/hard/crushed/possibly torn?I have one small oil leak from the rotor cover. I'm a little surprised by that, but I can see where the oil is coming out on the bottom edge, rolling down the engine side cover, and then dripping to the lower frame tube and the floor.
Thanks, Tom! This site has much to do with it.Looks good and sounds good, hard to beat that.![]()
I'll investigate. I do think I reused the o-rings on those screws.Is it possible the o-ring on that lower rotor cover screw is old/hard/crushed/possibly torn?
I looked at all three o-rings. They are all intact and wet only on one side. I suppose if they are too rigid, it will be more difficult to achieve enough pressure on the gasket, so I'll plan to replace them. (Edit: New o-rings are now on the way.)Is it possible the o-ring on that lower rotor cover screw is old/hard/crushed/possibly torn?
I was wondering about that also. It still has the pad on one side. I suspect it would affect things a bit, but it's hard to say how much.The rubber pad is kind of a mystery if it's not part of the minimum stop equation.
Even if losing both resulted in an overall range of advance increase, it probably wouldn't be near as much as the 305 advancer which can add 10-15 degree increase.I was wondering about that also. It still has the pad on one side. I suspect it would affect things a bit, but it's hard to say how much.
No I'm sure you're right, but at this point with some of these long-since NLA parts like these and springs, we're gonna have to shift our approach sometimes, that's all I was thinking.I've always assumed it was there to keep the weight to a desired position for the lowest idle level and to limit rattling. But, like most assumptions, it's probably wrong.
If you've already committed to the hitch, Harbour Freight has some cheap light trailers (that fold for less storage) that would work for one bike. Probably need to add some ramp or track for holding the bike on it.I just read @2wheel's post about the titling process in Pennsylvania and am now considering moving!
I am anxiously awaiting the completion of the final few steps in the process of registering this CB350K3 using a Missouri Salvage Title. The process for a salvage title is supposed to work like this:
I didn't know the definition of "major component" until I purchased the form earlier this week. That was a sigh of relief because it would be almost impossible to have VIN/title information for the source of most used motorcycle parts.
- Purchase vehicle with salvage title from registered salvage dealer.
- Complete required work to rebuild salvaged vehicle.
- Complete DOR Form 551 ($25 + $6 processing fee) and schedule vehicle inspection with local Troop of Missouri State Highway Patrol. The following documentation is required:
- Bill of sale for any major components used in the repair plus a copy of the title/VIN for the vehicle(s) from which the components were removed. Fortunately, the only major component for a motorcycle is the frame.
- Bill of sale or receipts for other essential components used in the repair, e.g., suspension components, etc.
- Documentation/receipts for any essential components that were repaired.
The other logistical issue I have is getting the bike to the inspection site. I have asked friends to help in the past, but I won't be able to choose the time of the appointment, so I decided it would make more sense to haul the bike myself. I don't have a trailer hitch on my VW Golf, but I think it's a smart addition for anyone who owns multiple vintage motorcycles and visited U-Haul on Tuesday. They didn't have all the parts in stock, so I am stuck for the moment. Once the hitch is installed, I can schedule the inspection and hopefully reserve a motorcycle trailer from U-Haul for the same day.
That would definitely work worth a little effort and is certainly affordable. I am partial to the single-rail motorcycle trailers, like the Ace from USA Trailer Store, but it's a lot more expensive ($1400) for the amount of use it would get. Their foldable version is about $2400.If you've already committed to the hitch, Harbour Freight has some cheap light trailers (that fold for less storage) that would work for one bike.
I don't really have space for any trailer in my single car garage (currently housing five vintage Hondas). So U-Haul will be my trailer source for the time being. The U-Haul motorcycle trailers are solid, have a built-in ramp, and offer proper ratchet strap attachment points.I've used the U-Haul trailer a couple of times, and it's a very easy thing to work with. For about $25 a day it's well worth considering, especially for those of us who live with no place to store anything as large as a trailer, even folded.
That setup seems pretty slick. I had assumed it wouldn't work with a small hatchback like my VW Golf. Is there a chance it could handle it?You could always use a carrier like I do.
Yeah, I was thinking in truck parameters when I mentioned it. I guess there would be the consideration of roughly 400 lbs of weight behind the rear axle, but if you put 2 adults and luggage in the back seat and hatch area I'd imagine it wouldn't be much different. Obviously the hitch carrier would have to be solidly mounted, I guess that's a question for the hitch installers. There wouldn't be many things the Golf would tow that would have that much tongue weight.That setup seems pretty slick. I had assumed it wouldn't work with a small hatchback like my VW Golf. Is there a chance it could handle it?
I use a tow bar type motorcycle carrier;it's small,easy to store and is meant for the 2" receiver hitch;tongue weight is a factor as it needs to carry 1/2 the weight(front wheel carrier)of the motorcycle while the rear wheel rolls behind it and the drive chain should be disconnected from the bike.That would definitely work worth a little effort and is certainly affordable. I am partial to the single-rail motorcycle trailers, like the Ace from USA Trailer Store, but it's a lot more expensive ($1400) for the amount of use it would get. Their foldable version is about $2400.
A truck would be nice, but I really like the Golf for 99.9% of my four-wheel needs. The back seat goes down and creates a decent cargo area that was big enough to bring home this CB350 project (after disassembly). I get low 40s MPG on highway trips with the 5-speed manual. The hitch should cover that last 0.1%, but I'll have to be modest with my towing ambitions.Yeah, I was thinking in truck parameters when I mentioned it.
For sure. I won't be buying a boat or a camper anytime soon, but it seems like a U-Haul moto trailer and one CB350 should be within acceptable limits. However, I don't think I'd feel comfortable hauling a bagger.Even with many options for trailers (from U-haul to other small lightweights) the tongue weight limit on the Golf is a factor.
Thanks — I looked at those. I don't have a lot of experience towing things in general, besides a U-Haul car dolly a couple of times. I'd be nervous about the bike tipping, so I'll leave the tow bar option to the professionals for now. Most of my expense will be to install the hitch/receiver. The trailer rental is relatively small.I use a tow bar type motorcycle carrier;it's small,easy to store and is meant for the 2" receiver hitch;tongue weight is a factor as it needs to carry 1/2 the weight(front wheel carrier)of the motorcycle while the rear wheel rolls behind it and the drive chain should be disconnected from the bike.
I've towed one of those U-Haul trailers twice, and I'll tell you they are not light. Most motorcycle trailers are light enough you can move them around by the tongue when there's no bike on them and they're disconnected from a vehicle, but the U-Haul bike trailer is quite heavy even when empty.I won't be buying a boat or a camper anytime soon, but it seems like a U-Haul moto trailer and one CB350 should be within acceptable limits.
Thanks for pointing that out — I hadn't checked the empty weight, but I just found it's 870 lbs, as @Grumpybugger has already posted. Looks like my bike is around 280 lbs. I found one article indicating the towing capacity of a 2021 Golf is 1600 kg with brakes and should not exceed 750 kg without brakes. Right now, I think I'll be okay if I keep it at low speed on mostly flat roads, but I'll do more checking.I've towed one of those U-Haul trailers twice, and I'll tell you they are not light. Most motorcycle trailers are light enough you can move them around by the tongue when there's no bike on them and they're disconnected from a vehicle, but the U-Haul bike trailer is quite heavy even when empty.
I'll see if I can rent a motor trailer elsewhere. That's a good idea. It's not a chain, is it?We have a rental company here that has motorcycle trailers much smaller and lighter than UHaul offers........just a thought.
No. They're a small two or three rail motorcycle trailer..depending. The only thing they're good for is hauling motorcycles. They probably don't weigh more than 300 pounds empty. Be perfect behind your Golf.Thanks for pointing that out — I hadn't checked the empty weight, but I just found it's 870 lbs, as @Grumpybugger has already posted. Looks like my bike is around 280 lbs. I found one article indicating the towing capacity of a 2021 Golf is 1600 kg with brakes and should not exceed 750 kg without brakes. Right now, I think I'll be okay if I keep it at low speed on mostly flat roads, but I'll do more checking.
Thanks, Tom! Definitely going to drive slow and avoid highways. I'll need to go about 11 miles each way for the inspection and there are two U-Haul facilities within about 2 miles of my house. The front wheel goes to the front center of the trailer, so the motor will be as far forward as possible. My car weighs about 3800 lbs, so about three times the loaded trailer weight.General rule of thumb is the tow vehicle should be substantially heavier than the loaded trailer. Always load trailer to have more weight forward of the trailer axle too, like 60/40.
Like was said, if you keep your speed down, any instability is greatly lessened. Stay off the interstates.
You'll be fine. Only load or unload with the trailer attached to the tow vehicle. They can easily tip back and, well, you know...Thanks, Tom! Definitely going to drive slow and avoid highways. I'll need to go about 11 miles each way for the inspection and there are two U-Haul facilities within about 2 miles of my house. The front wheel goes to the front center of the trailer, so the motor will be as far forward as possible. My car weighs about 3800 lbs, so about three times the loaded trailer weight.
