stl360+450
Here's the same seat buttons I used http://www.siriusconinc.com/products/detail/243
Perfect! Much obliged.
Post 13 here https://www.vintagehondatwins.com/f...toration-of-the-72-CL350-from-survivor-status has pictures of the installation
The seat came out really nice, that sheet metal edging is a great touch that often gets skipped, I think.
I can get down my 73 CL350 seat for a rivet shot pic, if you want. I'm sure craft and leatherwork shops have those studs if Sirius is out.
Good job on the seat cover stl360. Looks very professional.
Gary
Yes, essentially it's a rivet. The key for a tight fit is the washer before squashing the ears out. Rivet thru the cover, seat pan, cover again, add washer, bend ears 90 degrees and finish by squashing the ears flat.Nice. Looks like you actually used rivet style buttons. Is that right?
I'm sure Honda had an explanation for the differences and even whether the 'I' and 'II' were relevant to anything, but this is not something I've ever been aware of. And I find it odd that there would be a very slight difference in the diameter of the stub in the cam for the advancer.
Serious progress. I love the dark side pic at the end.
The offset crank/clutch gears are for noise reduction
I found the offset primary gears a little odd, but I suppose there must be an engineering reason for it. Reduced wear maybe?
Straight cut gears are always noisy. Honda's solution is basically 2 sets of gear that are making noise but because of the offset the gear noise is cancelled by each by introducing an opposing noise. Has to do with frequency wave forms.I remember hearing once that those straight cut gears are more efficient for power transfer but are noisier than helical cut gears. Helical cut is more expensive to produce, the Benly's might have been the last ones Honda did.
I wonder if it was a combination of Honda's ongoing effort in that era to make these bikes as pleasant and friendly to the general masses as possible in a time when bikes were still widely vilified as being associated with 'bikers', most of whom had bad reputations then. Small but incredibly reliable bikes that got ridiculous fuel mileage and had quiet exhaust all fit into the narrative Honda used in their "You meet the nicest people" commercials that turned the industry into what it became not much more than a decade after their arrival. And of course, not long after that the EPA came into being and started locking down not only pollution levels but noise as well. Even driveline and intake noise was reduced afterward.
Don't forget the spacer between the lower front mount tab and the engine.
Thsnks. The spacer is in there, it's just hiding at that camera angle.
It wasn't that I couldn't see it as much as I know how easy it would be to forget. But good to know you didn't, which I really didn't think would be the case anyway.
Good to see it coming together, and the silver frame looks really nice.
We're getting close to the time when the merit of my color choices will be put to the test. I remember you were not quite sold on the combination of dark and light silver and I have to admit I won't know for sure how I feel about it until it comes together.
It's going to look great, already does!
Looking really good.
I like the 2 tone silver.
You shouldn't the need thick spacer at the bottom.
You also shouldn't need to heat/freeze anything. The lower bearing should tap down pretty easily and the top bearing just drops on to the stop.
You will come up a few threads less at the top, this is normal.
Assemble the old bearing and races to sit on a bench top. Now put the new bearing ass'y next to it. You'll see the height difference and by adding one or the other washer you'll get it very close to the sameThanks! I've read in other threads about 1mm and 2mm spacers, but my kit came with 2mm and 4mm options. I am currently planning to use the 2mm option based on the measurements. Does that seem off to you?
I'm sure you removed any powdercoat from the land where the spacers/bearing sits so all is perpendicular. Along strip of emerycloth will polish the interferance fit area of the lower triple so it can be tapped on easily.
View attachment 24003 View attachment 24004
In that case just be sure there enough but minimal clearance of the lower triple to frame. Be sure to turn the triple back and forth to check.I've read about this, but didn't think it would be appropriate since I'm mixing the 350 frame with 360 stem and bridge. I don't have all of the old 360 components, but I should have all of the old 350 components. I will try to compare with the 350 lower stack.
I would start with the 2mm washer
Do you have the 350 stem to compare to 360 stem? That should be enough.
Looks good. Don't forget you D washer on the pinch bolts.
