911hillclimber
Think I've got it today.
Stripped the carbs for the 8th time, cleaned and cleaned again, poked all the holes etc and re-assembled.
It started just like that, instant on the electric starter and I warmed it up.
Had the usual hot side/cold side and it almost switch over sides during some tweaking, BUT I seem to have found a sweet spot.
The tick over is close to a Harley though the tacho says 1800 sounds more like 3 rpm to me.
The pilot screw seems close to redundant but has with some combination of throttle slide adjustment seem to have bought the engine to balance, the silencer temps are really close.
Boyed by that, the next step is to fit the air filters and see if things are all ok after and re-tweak. These little bike can be sensitive I've read to the choking effect of the cleaners, but I hope my custom foam ones will win through.
Following a post on a UK classic bike forum, I still have a nagging doubt about the drillings by the air ratio screw.
There is a short drilling with ball bearing seals and you cant get a wire to it, so going to strip the carbs again, and take the bodies to Villiers Services, close to me, who do old bike stuff and get them to US clean in thier heavy duty tank. Might then leave them in cellulose thinners for a few days soak and see if the screws have more effect on the engine.
Worth a try providing they are open due to bloody Covid 19!
