RobMan
Oh forgot to add I pulled the plugs and they didn't show any fouling and were actually cleaning the tips from running and the porcelain whitening up.
Some of the aftermarket gas caps have wadding material inside that may restrict airflow. On my CB350 build, I bought a black gas cap from 4-into-1 and removed the wadding before installation. Can yours be taken apart like the one shown below? If so, you might check for wadding.I also wonder if the gas cap is venting properly, it is new one that i bought off Amazon and looks nice but may not be venting properly so I will do the next run with the cap loose.
Thanks for the tip! Yes mine looks just like that and I will take it apart and check for wadding. They do advertise it as being less likely to leak than the original and that is probably what the wadding is for.Some of the aftermarket gas caps have wadding material inside that may restrict airflow. On my CB350 build, I bought a black gas cap from 4-into-1 and removed the wadding before installation. Can yours be taken apart like the one shown below? If so, you might check for wadding.
Someone had purchased the same style cap before me and I benefited from them having a venting issue and posting about it.
Hope springs ever eternal which is part of the toolbox needed when working on these machines.It will be pretty sweet if that was the source of your initial issues.![]()
Yes that is a good idea, pull over and shut petcock and bike off immediately and then pull the bowls and see what the levels look like. It seems like it is running out of gas but heck who know, bad condenser or coil failing when stressed a bit. I will find it, just don't want to throw money at at the problem.If you're able to safely pull over when this happens, I would shut off the petcock, pull over, and check the fuel level in each bowl. It would be nice to narrow the problem down.
It's a pretty compelling story and a solid diagnosis effort. I've heard of this happening, but have not experienced it first-hand.That's my story and I'm sticking to it.
We've actually seen one case of a collapsed inner header wall a couple years ago, I want to say it was on a Bomber.It's a pretty compelling story and a solid diagnosis effort. I've heard of this happening, but have not experienced it first-hand.
Possibly and I may give it a shot. I was thinking of cutting it right at the bad section just to see what had happened. I could always practice my welding skills or lack of after taking a look.Any chance you can remedy the collapsed wall using brute force? (hammer and some sort of steel rod) Then you could do a little more riding while you wait for the replacements.
Wait, you guys have bill counters??It looks like none of those bills are making it to the stack at the front of the bill counter! I think some must be getting syphoned off to DSS and CMSNL as fast as they're coming in.
My bill counter has the same problem!
Hell. I was going to drop the link for the Delkevic 2-1 they have for the K3-K7…Got a reply from Matt at DSS this morning and the down pipes they sell are single wall and chromed. Looked around a bit on line and all the used ones are, well used and the only new ones are from Thailand and once you include shipping and tariff I decided to bite the bullet and placed the order this morning with DSS. Also ordered new header to muffler clamps and a couple other small items. All the items are coming from across the pond so will be a couple of weeks. Patience weed hopper patience, when you can take the bolt from my hand you will be ready. BTW the cost doesn't bother me at all.
This is where those bill counters come in handy...Hell. I was going to drop the link for the Delkevic 2-1 they have for the K3-K7…
Thanks Bob, I couldn't remember if it was Troy's or yours or whose it was.It was my Bomber that had the collapsed inner tube on the header. I tried to hit it with a long tire iron and a 4 pound sledge hammer, but no luck. The curve makes it mostly inaccessible with a straight piece of steel. Just to prove the theory, I ran water from the hose tap into the engine end of the header, and it just overflowed, quickly. Replacement did the job, instant satisfaction.
Here's a link to my thread from February, 2022, where my post sounds just like yours.
"A Bomber Barn find", page 2
I was almost going to suggest considering aftermarket options like that. I like the look of the 2-1's as long as there is no kicker interference. They do complicate carb balancing on these bikes.I was going to drop the link for the Delkevic 2-1 they have for the K3-K7…
Wow that got really deformed.For inquiring minds I did cut the header at about where the obstruction started.
You can se how badly it is bulged in here. Also note there is actually 3 layers of pipe with the innermost coming down about 6 inches. The middle layer goes down until about 6 inches from the end of the pipe. I believe my theory of water trapped between the two outer layers is correct as you can see a small gap in the second photo, looking up muffler end, where moisture slowly infiltrated over the years and when pipe started heating up the layers sealed and steam does what steam does.
View attachment 54956View attachment 54957
Thanks, I hope it is the solution as well. Wish the headers had been available here in the US, hate have to twiddle my thumbs waiting for them. Tried seeing if I could get the inner pipe to knock or pull out so I could weld the header back together but no luck so far. I need the equivalent of a metal grinding rotorooter. BTW glad to hear I'm not the only one having a hard time finding my threads with the new pic!Nice find Rob! Hopefully the new headers will be the solution. BTW nice new picture. Funny I was looking for your old pic to see what's new on your thread. Took me a minute to realize the "new you"![]()
Harbor Freight to the rescue, used a cheap cut off tool to cut the pipe after making alignment marks. I had to be careful knocking the inner pipe out by crushing it a little at a time with big vice grips and a long punch helped.I'm pretty impressed with the welding! Given all the brute force involved, it's amazing that you could still mount them up.
Sounds like forward progress with regards to the floats!
Addendum: the underside of that rear fender is clean enough to eat off of!
I check floats for leaks by boiling some water and submerging them. Any leak will immediately bubble.I just hope the old floats don't have pin holes or cracks. I got the new ones from 4into1 and I think I must have bent it or something.
To confirm, with a caliper do you measure with or without the gasket?
I'm guessing it will be more obvious when you (like would happen to me) pick the wrong one to put on the side you're starting on.... you know, the 50/50 choice that's always wrong the first try, or maybe you win this awardOnly visible difference is not marked with an L and R which could be a problem for dumb old country boy.
They do look nice. Not to undercut DSS, but it makes me wonder if similar quality pipes are available any cheaper directly from the vendors in Thailand. I've found other exhaust parts that way through eBay for other bikes, like CB350 headers and a full exhaust for a friend's Yamaha XT250.So Shiny!!! Made in Thailand and feel like solid heavy materials.
I thought the same thing myself but I knew with DSS having a store front in the US there is no issue with tariffs and I didn't want to get in an issue with customs. I also like being able to reach out to DSS customer service if needed.They do look nice. Not to undercut DSS, but it makes me wonder if similar quality pipes are available any cheaper directly from the vendors in Thailand. I've found other exhaust parts that way through eBay for other bikes, like CB350 headers and a full exhaust for a friend's Yamaha XT250.
I'm anxiously awaiting warmer temperatures as well. Hope you can try these out soon.
drive.google.com
Sounds good, engine's pretty quiet inside and the idle sounds nice, steady and even.Warmed up enough I ventured into the garage and got the new headers and old mufflers installed. Took a bit of rubber hammer to persuade the right muffler to go on far enough. Installed the air filters and went for a start up and as usual a bit cold natured but after I got it started and warmed up a bit seemed to be running well. Too cold for my old bones to go for a ride but I am pretty confident she will behave herself at least for a short run. I will have to take it on progressively longer rides to build up confidence. I also need to add the Motorcycle coverage to our AAA account.
Short video of it idling, no Vrooom Vroom.
Idle 2-24-26.MOV
drive.google.com
