ballbearian
Well, it was all true. I guess that's why they threw me out of politics, because I wouldn't lie about everything, including inhaling.Yeah, that too![]()
Except for the impassable muffler on the one pipe, that is kind of what I was thinking. After a shooting session I use a bore snake (a nylon rope with a weight on one end and an embedded bronze bristled cylindrical brush), even though a rigid cleaning rod works well on a straight bore, but a curvy exhaust needs some kind of snake. If my plumber's snake doesn't work, I'll use some 1/4" steel cable with a frayed end for a brush in my drill.It would be interesting to invent a pipe cleaner with a piece of plumber's snake at each end and a wire brush in the middle, so you could run one snake through and then pull the wire brush back and forth in the pipe. I guess it would take two people. Like a giant piece of dental floss. Probably not worth the effort. I can say, from personal experience, it would be smart to just run a snake through the pipe to be sure there's nothing blocking the way.
Mikes XS has them. They are out of stock right now. You may want to contact them and see if they are going to restock. The XS650 uses the same size and spoke number as Honda. Check out my post on my restoration about the re-lacing of my wheels here:That makes sense even with steel rims and stock tyre sizes. Pretty slim pickens on rims in 36 hole 2.15x18, none at 4into1.
Maybe I'm starting to get an eye for race wheels, that bike above looks good wheel-wise.
I was listening to this Dutch guy talking about his 50cc racer and they go for the skinniest tyre/rim they can find but hey, it's just a notch or two above bicycle speeds.![]()
You made a great thread there and hopefully will inspire others to give relacing a go. I got to admit just a bit of jealousy for Buchanan's spokes (maybe next time). We called them single butted, as opposed to straight gauge in bicycle speak.I also got spokes from Buchanan's in Cal. They were Stainless so a little pricey,
Ok, 'swaged' in motorcycle speak but 'single butted' in bicycle speak, I can't help it, I was a shop monkey for 20 years.My spokes were "Swaged" they are 8 gauge in the center, 9 gauge towards the rim. That's how the stock spokes were on my CB360t. At the time, the total cost for the spokes for one wheel was $108. That was more than the cost of the wheel. Wheels were on sale for $69 each and free shipping. The 2.15 wide rears gave a better profile to the stock 3:50x18 tires. As I said in the that thread, the bike really handles noticeably better with that setup.
Darn good idea. I've got a couple dead maintenance crew cast offs.If your looking for a heavy duty flex drive, weed whacker is around 3/16" and 5ft long.
There are probably 'professional' versions which are heavier?
If it was a production afterthought, it was fairly prevalent. I remember seeing these in some of the new bikes I assembled out of the crate back in the day, and my CB350K1 has one also. Mine was plugged into one of the grounds that come from a sheet metal tab spot-welded to a mounting nut for the headlight case.I found this green ground pigtail in that must've fallen into the carb boxes and can't remember where it's from. Seems like a Honda production afterthought, maybe used to fit turn signals to a bike that came without.
Filter tins painted and new filters test fitted. I wished I'd bought the filters from Kevin at Srambler, he was cheaper than these from ebay, they are probably very similar. The retroCB side covers need painted and I'm wondering if the Duplicolor I used on the CB160 will match ok with the Hawaiian Pacific Blue of the original paint on the tank.
When I bought this bike, it had no carbs, so I bought a nasty complete pair on ebay for kinda cheap. There wasn't much available then but they were comeplete. I found a couple issues and back-burnered them for a while. The stuck small emulsion tube and the broken off tip of the idle jet in the worst side, right side, have been overcome but the throat is fairly pitted. Next is to try cleaning up the throat and blow all the passages. I hope I can save this right side 722 body.
Thanks. I do love a 'lost cause' however, I may have to cry uncle on this, but not yet.YIKES, that carb body!
I bet I have a 722a body in my collection that you can have. Just let me know and I will take a look.
I have accumulated quite a collection of the 3d and 722a carbs and parts.
I have already cried uncle on your behalf. Good lord man, please let me know when you have come to your senses. Only then will I pull out the box that is inscribed "carb bodies" ... for a looksee!Thanks. I do love a 'lost cause' however, I may have to cry uncle on this, but not yet.
Yes, truck driving dog does look a little psycho but only because it forgot to throw a few drops of Lumify before getting behind the wheel.A true friend will harsh your mellow when you're humming the Siren's song of cheap parts.
I'd come to my senses, if I could find them. My garage is my life and it's a mess, I may have misplaced them, if I ever had them. Is there a part number for that?
enlarge this 3rd pic for pothole close up.![]()
It's like this:
I find this wallflower at the dance. Maybe she'll clean up nice at the House of Butte-tay. How will she dance, is the question? Just because she's coyote ugly, she may dance like a Dervish, or maybe she'll have some weird behaviors. Hmmm.
I may need a Target intervention, even if that dog driving the truck looks psycho.
Right. 722a JJ, the leper.Which side are we talking again? Left or right?
I'll open the psycho dog box tomorrow and let you know what I find. I have the brass stuff too, so if you need a certain hard to source piece speak up.Right. 722a JJ, the leper.
Damien, you're a prince. So far even the bowls, rods, plates, slides, etc. look ok. I've even got new chromy tops coming. I hope you find a single and don't have to break a set. Just let me know. My carb career should last a while, with at least 3 more sets to go on the bikes here.I'll open the psycho dog box tomorrow and let you know what I find. I have the brass stuff too, so if you need a certain hard to source piece speak up.
I believe the carb bodies are identical, the only difference being the jetting & setting from the factory.Just curious. Is there anything good or positive about the 3D carbs on the 350's? Or are the 722's just better all around?
This one didn't have a mate so it is happy to have one soonDamien, you're a prince. So far even the bowls, rods, plates, slides, etc. look ok. I've even got new chromy tops coming. I hope you find a single and don't have to break a set. Just let me know. My carb career should last a while, with at least 3 more sets to go on the bikes here.
Beauty! Good of you brother.This one didn't have a mate so it is happy to have one soon
Still has its lovely factory rainbow finish which is always nice for originality sake. I like to use Dawn Ultra if it is heading for an ultrasonic cleaning. It won't hurt the finish like some other products do.
That is a gem. A JJ and a LAThis one didn't have a mate so it is happy to have one soon
Check your PM's
I've got a couple low priority sets to do sometime, so I'll check that out. I did notice Kevin at Scrambler sells kits for both types.I believe the carb bodies are identical, the only difference being the jetting & setting from the factory.
I also tried the simple green once, and once only. I had the exact same results as you mentioned above. It ruins the finish and I definately do not like the smell.That is a gem. A JJ and a LA. Now a fluid dynamics duet.
Thanks for the Dawn tip. I'm ditching the Extreme Simple Green aircraft industrial sauce, It makes carbs very dark if too strong or too long a soak, maybe good for de-mossing the old van.
PM sent.
They came from ebay this way. Flaps and springs are still good. IIRC, before flaps were 'invented', some carbs just had a small hole to have a minimal air flow. I think it was you that wound your own springs. A heroic save for sure.Hmm, wonder where the bottom edge of that choke plate got away to. It probably spoiled somebody's day. Got springs on those choke flaps?
I have some old 3D bodies, but no choke plates left in any of them.
I did wind my own choke flap springs. The jury is still out as to how heroic that was.I think it was you that wound your own springs. A heroic save for sure.
I was wondering the same thing. I'd say there is a high likelihood of that.It does make you wonder if that piece caused its bike to end up parted out.
So those aftermarket diaphragms have locating tabs? That’s nice but you still gotta make sure the piston holes are facing the right way.The new diaphragms from Scrambler fit really nice. I was worried that the old ones wouldn't come out and or that the plastic ring would be a problem. The new ones needed to be gently worked back into the grove with my thumbnail and was able to rotate the piston for proper alignment with the little tab on the diaphragm.
The bodies are back into the ultrasonic for another soak but with just hot water and a good amount of Dawn Ultra dish soap, instead of the Simple Green extreme.
Yeah, one of the choke plates is missing it's lower edge, but I don't think it will matter much.
I'm still wire brushing the hardware bits, they were kinda crusty even after a soak in the Bilt Hamber Deox-C. It does dissolve the plating which leaves a blackish coating on everything that can be scrubbed off with detergent.
I haven't measured the jets in Scrambler's kit but may use most of it. Pleased to see the kit even includes the tiny washer to support the O ring for the air mix adjuster screw.
The replacement right side carb body (Thanks, Ausman1000 !) and the new felt shaft seals should both be here Monday.
There's a number of the diaphragms that are made with heavier rubber and that will delay the piston rise which in turn will probably cause a flat spot in the power curve.So those aftermarket diaphragms have locating tabs? That’s nice but you still gotta make sure the piston holes are facing the right way (towards intake valve I believe?).
I always wonder if those aftermarket diaphragms react the exact same way to vacuum as OEM. Kinda critical operation isn’t it?
Which are those so we know to avoid?There's a number of the diaphragms that are made with heavier rubber and that will delay the piston rise which in turn will probably cause a flat spot in the power curve.
I can't remember the bad ones. I've been using Sirius Consolidated for them http://www.siriusconinc.com/products/detail/1070Which are those so we know to avoid?
Jim, perhaps when you have a moment you can give us a micrometer reading for the diaphragm thickness of those Sirius ones? The ones I have are from Scramblercycle and I would like to compare.I can't remember the bad ones. I've been using Sirius Consolidated for them http://www.siriusconinc.com/products/detail/1070
They also have the preformed Viton float bowl gaskets again, the ones that don't swell up and distort. http://www.siriusconinc.com/products/detail/1506
I'd love to but I don't have any at the moment.Jim, perhaps when you have a moment you can give us a micrometer reading for the diaphragm thickness of those Sirius ones? The ones I have are from Scramblercycle and I would like to compare.
Thanks!
Oh, thank you Ray for that link. I see you've made a few edits so I've marked it to watch now. I just re-read the entirety and it will be very useful in completion of these and the other carb sets, yet to do.I also don't know the thickness of the ones from Sirius, but they seem very light and flexible, and seem to be of high quality. Orient the holes toward the choke end of the carburetor. I posted pictures of mine HERE.
I made the mistake once of running my CL350 carburetors in Simple Green. After they turned black like yours, I ran them for a long time in my friend's industrial sized ultrasonic cleaner. He even ordered a special solvent we had read good things about. This was no small deal for him, because his cleaner held about 30 gallons and was equipped with a skimmer so that it only rarely needed to have the solvent changed. Here is how they came out after all of that:The Sixth Plague. Boils
Must be the fat in the Dawn Ultra. Will try LDR's fav, Pine sol. Or maybe it needs a statin for cholesterol. Weird.
Must be something along those lines. I’ve heard of other people getting darkened parts also. I didn’t dilute my solution with water. Maybe it’s the cheap harbor freight cleaner. Maybe the frequency has something to do with it. But I’m guessing.The difference is probably in the concentration. I would be delighted with parts like in your picture.
