Only downside to that is the appearance, they don't look the same as the OEM bolts.I source all my hardware from Bolt Depot, much cheaper than buying OEM stuff
For their sizing (increments of 5's on the lengths), Bolt Depot works well when you've got enough volume to justify the shipping (although the 13mm head size on their M8's instead of Honda's typical 12 does annoy me sometimes). I've found the Auto part workaround as the best solution to the "pick 2" dilemma of the Correct/Cheap/Fast decision tree.I source all my hardware from Bolt Depot, much cheaper than buying OEM stuff
Bolt Depot does offer JIS sizing with the 12mm heads. I’m just not that big of a stickler and none of my builds are 100% factory stuffFor their sizing (increments of 5's on the lengths), Bolt Depot works well when you've got enough volume to justify the shipping (although the 13mm head size on their M8's instead of Honda's typical 12 does annoy me sometimes). I've found the Auto part workaround as the best solution to the "pick 2" dilemma of the Correct/Cheap/Fast decision tree.
