Power Chambers Explained
LongDistanceRider
Super Moderator
Staff member
Vancouver, Washington USA
On the SOHC CM/CB 400/450 series Honda refers to the big ugly can under the engine as a "Power Chamber" although you'll find reference to pre-muffler, expansion chamber, etc. I'll stick with Power Chamber.
Exhaust gasses enter one side turn and exit towards the opposite side, from there the gasses can expanded and have 2 exits through either muffler. The Orange spots in the picture are where the bypass holes exist.
It's been long established that the longer the primary exhaust pipes are the lower in the rpm range where power is produced. Shorter pipes produce more high rpm power. It seems Honda wanted to have the best of both worlds, real good low rpm and high rpm at the same time. Normally you get to choose one or the other. Good high rpm power while sacrificing low rpm power. Or you can split the difference and get good mid range rpm power and sacrifice less of the high/low power.
In the picture you can see the Red inlet gas path emptying into the chamber and exiting thru the Green outlets. Honda in their design has added a number of holes in the curved section (Orange) that allow high pressure/rpm gasses to travel straight thru. The gasses under low rpm/pressure will follow the curvature of the pipe which extends the pipe length for low rpm power but when the pressure rises some/most of the gasses will go straight through which gives high rpm power.
Honda apparently went through 23 different versions of this before settling on the design. The internal pipes change sizes also at different points
20150827_163919_zpsqieolykw.jpg 20150827_163929_zpsectnyiie.jpg 20150827_163859_zps2eqdgczs.jpg
The Power Chamber also serves as a balance/crossover tube, like the ones you see on older Brit bikes. Those tubes tend to balance the exhaust pressures between pipes resulting in smoother power.
For more information concerning exhaust systems pickup a copy of Scientific Design of Intake and Exhaust Systems, written in the 60's and still used as a reference by engineers.
I can't remember which member uploaded these pictures originally but I do appreciate it.
Just researched the Honda part numbers. Seems there are 2 versions, by engine size not transmission. Interestingly the 1986 CB450SC uses the 400 version. There's no info on the Sankei numbering.
Assemblies where 18310-413-013 is used
Note to add here. The 450 version has the holes in the curved pipe for better flow. The 400 does not have them.
