Just mount up an old AOL CD, they're good for 15,000 rpm before they scatter.
LMAO... I assume you've experienced the rev limit?
I guess you could run a lightened rotor, sans magnets.
I feel like there should be music and some kind of special introduction... after 378 days, my head has been returned to me.
I wouldn't mind getting my head rebuilt. I've been abusing it for 76 years and some of its connections are getting a little unreliable.
Looks really good there Tom, he did a great job..... I feel better too. My gauges for the CB350F have been in Holland for 6 months now, so only a fraction of that year + time.![]()
Very cool. Precise, tiny, intentional scratches are something to get excited about. That titanium jewelry is pretty impressive too. Anything special about the seats or guides?
Budget and sensible. I guess spring choices may have more to do with cam particulars than valve mass.
Tom...... I might have a "top-secret" suggestion for further easy and inexpensive performance improvement for this engine.....
Will reveal it during our next phone conversation....
Here's a hint.........
Looks nice.
I'll also be using a modified advancer with the breaker cam lobe trimmed down to less than half the points-open duration to ensure it will get plenty of dwell and rev cleanly to well past the rpm range the engine will turn, probably around 10,500 to 11,000.
Was this modification done though a local machine shop or was it part of the work that Schumann did for you?
It was done on the bench grinder in my garage, then filed smooth and finished with emery cloth. The reason it doesn't have to be precision is because it's the backside of the lobe that you remove. Letting the points close sooner and stay closed longer (while still opening in the same location) is all you're doing, and as long as the "exit" ramp doesn't cause accelerated/excess wear to the rubbing blocks on the points, the other area the points don't touch doesn't have to be perfect. This one didn't turn out as nice as the one I did almost 50 years ago so I didn't post a picture of the actual area involved, it wasn't brag-worthy but effective.
Thanks for the explanation and photo -- it helps me (maybe others, too) learn as I follow along with your build. I haven't had any exposure to drag strip performance modifications, so everything is new to me.
(ancientdadThis is really a modification that would work on anyone's 180° twin still running points, and it doesn't add to performance except to help eliminate points float at high rpm and increased dwell for stronger spark at all speeds. I learned it in high school from a Gordon Jennings article in Cycle magazine, along with how to make an energy transfer magneto out of a stock alternator on the SL90 which also worked and allowed me to run that strictly off-road project bike without a battery.
Cool stuff. In Steve's lesson on dwell times he mentioned the possibility of heating up the coils at low RPM a if the dwell is increased. For a drag bike that's obviously not a concern, but what about road use?
Looking at your photo a bit more, those advance springs look really fresh. Did you find NOS springs, a replacement, or what?
Remember I'm running that advancer on my red 450, that picture is from the one I modified for it. I plan to do the one for the drag bike as well, just haven't done it yet. So I guess that answers the long-term reliability question about the coils since I've put over 2700 miles on the red bike since the original build, including idling around Barber in the late summer heat for a week at the vintage festival in 2018 and all the other riding before and (especially) since.
Looking at the gears, the larger gear once fit and unless there’s a specific relief or pocket to accommodate the diameter it’ll still fit only on the other side. My recollection is the case wall in question is flat, no relieving.
Or cheat and count the gear teeth, then enter that info into www.gearingcommander.comIf it were Me, I would count all the gear teeth, grab a pocket calculator and work out the actual ratio in each gear.
I could be wrong, but it looks like the x'd gear set will be faster in 3rd than 4th.
stock: 1st- 2.41, 2nd- 1.4, 3rd- 1.03, 4th- .90
x-ed : 1st- 2.41, 2nd- .96, 3rd- .71, 4th- .90
gear tooth count from the cmsl parts book.
Sounds like a good time, Tom! Good to see an update on this project.
The best thing you can do to your crankshaft is to take it apart, clean and press back together.
