Today I spent a few hours with this project. I've organized a 10x10 storage unit as a work shop. So armed with a pizza and a few beverages...
I mounted the swing arm, passenger foot pegs, and shocks, then strapped the frame to my bench.
Next up I installed tapered roller steering bearings and added the top triple.
After that I had a new idea to try for disassembling these forks. I removed the jaws from my old bench vise and found a bolt to fit the threaded holes. I cut two lengths and filed one end of each to a point, about 60 degrees. Threading one into each opposed hole, I was able to use the vise as a pin spanner, while I wrapped a rag around the fork lower and gripped gently with a large pair of channel-lock pliers. I was fairly amazed at how easily the chrome caps broke loose from the steel fork lowers, I didn't even need to try the second set of holes. Same with the other fork, it was just amazing.
After disassembling I noticed the fork bushings were in really good shape, no way did they have 18,xxx miles on them. I'll clean everything up and replace the seals next shop day.
Some pics:
And this was a bit of a surprise but it looks like these fork springs have progressive windings, tighter coils at one end than the other. Thoughts?
