7 Inch Motorcycle Multi Projector LED headlight w/brackets DANG!
SpeedMotoCo
Forum Sponsor
Bend
This is one of our most popular headlights, that you are sure to love! This is a perfect headlight for a variety of bikes, from stockers, caferacers, off road dual sports, and everything in between! This comes with a 7" LED headlight with billet mounting brackets. This headlight is very bright and lays an excellent pattern, DOT approved. All billet brackets that swivel so your fork width is not a concern. Headlights and brackets are also sold separately in our store if you want to purchase one or the other.
Use Code VintageHondaTwins10 to save 10 percent at checkout.
Link to the Website: https://speedmotoco.com/7-inch-motorcycle-multi-projector-led-headlight-w-brackets-dang/
dang_headlight_front__46698.jpg dang_headlight_side__31992.jpg dang_headlight_back__14125.jpg
Specifications/Notes
  • Has a short overall length 80mm length from front of mounting bracket
  • 100% 6061 made on earth aluminum
  • 2 piece fork clamp for easy install
  • fits 33-58mm forks see
  • 304 stainless hardware
  • 7” multi projector led headlight this headlight insert is super bright and very cool. Featuring 13 x projector leds for high / low beam + top & bottom horizontal led daytime running lights.
  • Perfect upgrade for harley davidson and jeep headlights.
  • specifications
  • 10 - 30 volts 75 watts colour:
  • 6000k cool white lumens: 4000lm waterproof:
  • ip67 cast aluminium housing h4 connector plug function
  • 1: low beam function
  • 2: high beam function
  • 3: daytime running lights dimensions
