RobMan
Much cooler here in North Carolina today so spent some time in the garage. Got the carburetors installed but not 100% happy with the cable routing. Got the throttle and clutch cables routed correctly as best I can tell but happy to accept som e constructive critiquing.
Throttle cable along left side. Cable splits on either side of the crankcase vent.
Clutch cable along right side.
Concerned where clutch cable is press up on left carburetor throttle shaft/arm. Close up.
None of this is permanent so I appreciate suggestions. I have got to pull the left carburetor again anyway as I noted the piston is a little sticky and not dropping all the way when pushed up. Got better after I worked it a bit but want to pull and see if I missed a small burr or something.
![IMG_5108[1].jpg IMG_5108[1].jpg](https://www.vintagehondatwins.com/forums/data/attachments/45/45843-f27b82aa1218594d81e129c7219745a7.jpg)
