Well I didn't read the for sale instructions on DSS for the fork gaiters.
So I received only one of the gaiters. Try again! The second one is now on order, so I will eventually have a matched set.
I did repaint the lower sliders in Joe's mini indoor paint booth a few days ago, so they look good again. Once I get the second gaiter I can install the front forks.
I ordered a new head gasket again. The aftermarket old gasket set I bought has been a disappointment. Non of the gaskets are fresh, so something to consider when buying a 50 year old gasket set. The holes are not well aligned for the parts with some adjustments needed. The head gasket would not fit the studs without some filing of the one outer hole. I then realized the head gasket was about .5mm thicker than the one that was on there. Since the rear two outer studs are oil feed holes to the top end there are two green Viton O rings that seal the area. The O rings are 1.5mm thick and the replacement head gasket was 1.95mm thick. The head gasket on there when I took the motor apart was 1.3mm thick.
I was concerned that even when squished the thicker head gasket may not allow those sealing O rings to seal correctly. There was also so very slight corrosion on the fire rings on this head gasket too. For the sake of $45.00 Canadian it wasn't worth a roll of the dice. I will eat the cost.
A note to self. "Don't buy anymore 50 year old aftermarket gasket kits."
Forks with one gaiter. The good news is the new gaiter fits both the lower slider and the upper headlight bracket perfectly.
View attachment 52835Ets
