ballbearian
After looking what these seats go for, in decent shape, I bought a cheap, rusty, bent but intact one to re-do. Here is is before tear down, I did have to grind the tiny nuts off the chrome trim strip screws and seat strap bolts too (as they were peened over).
The hooked pick worked best for minimal straightening of the pointy teeth holding the cover on. I've learned to be gentle with them because they can break off pretty easy and that would make for more work to come up with a way to replace them.
Pretty messy with all the crumbling foam rubber that falls out. I tried to save the contoured curved pieces that can give shape to the 1 inch new foam slab that will go over top and are not crumbling. There were 3 layers in this seat but I might only need one to give a good shape. The stiff plastic sheet against the springs was, of course, a goner.
Time to straighten the frame and order another cover and a slab of upholstery foam. I've used "firm" density foam which is somehow rated at 44lbs. vs. "medium density" at 36lbs. seems to feel about right.
If the saved foam rubber, that has the nice contour starts to crumble, then I'll resort to shaping a gardeners kneeling pad (about 1" thick) with my sanding angle grinder, to use as a base layer and to give contour.
To cover the springs I'll use some salvage vinyl/foam composite gymnasium flooring that I was given a large roll of. It seems perfect.
So, $85 for the old seat, $43 for a new cover from ebayer gumtwo, $20 for upholstery foam and maybe $15 for chrome edge trim if the original doesn't cut it.
$168 total (or less) ain't bad since ebay ballpark was $300 and up.
We'll see how this one turns out, the last one I did is really comfortable.
