Nick_Brox
Okay. I forgot the starter grounds through the engine. It is okay if there is continuity between them.
You should be careful of overtightening things, you're lucky only the nuts stripped instead of breaking off a stud. The fit is normal, the flange isn't intended to be flush against the head. You put new gaskets in and tighten it until it's tight and the gap is even on both sides, then after you run it a bit you should snug them up again as the copper gasket crushes... but what we see in the pic is normal.
With engines it is always best practice to go by manufacturer torque recommendations. Torque wrenches aren’t super expensive, and will save you a lot of pain and money in the long run if you learn to use them. Some things can be German torque... “Gütentight”, but suspension brakes, steering, wheels, and engines is not an area that I like to mess with.
If you haven't already, you should pick up a modern rectifier/regulator combo from Sparck Moto, the best unit for the best price and he gives great support for all his products too.
http://www.sparckmoto.com/Products/Detail/7
The interior surface of the hose has to be smooth so a flex hose is a bad choice.
On the stock carb, does the air boot fit into the carburetor or over it? I think that’s part of my initial confusion
Found this at Home Depot and pulled the clamp off the small side:
It was snug on the air box side, but I figured it couldn’t hurt to add 6 twists of stretch/seal tape to be sure. Final result:
Looks like the bearing Phillips head screws aren’t tight. Anybody know the torque spec of the top of their head?
There is no torque spec for JIS screws, you just get them tight with the proper tool - and it's not a #3 American phillips screwdriver, it's a #3 sized JIS bit or screwdriver. Not so sure that is your problem since it's dripping like a leaky faucet. The noise just sounds like valves grossly out of adjustment
You could, but great care needs to be taken. You have to find the spot where all the valves are closed - essentially where the cam chain on a 350 is supposed to be adjusted - and then remove the cam chain tensioner from the back of the cylinders to remove tension on the camshaft (but only after locating the position where all valves are closed, NOT before). THEN, AND ONLY THEN, is it safe to remove that cam bearing. It will slip off with little to no force and result in damage to the aluminum bearing (bushing) surface, but you must be careful not to pull the rocker shafts out with the cam bearing or you will likely never get them back on the shafts correctly without pulling the engine and the top cover off. Then you can put the gasket on the proper way, slip the cam bearing back on and tighten the screws.
Good - hopefully there was no resistance when you took it off so it will go back on without gouging the bearing surface. It's an easy mistake to make, the gaskets fit both ways and seem correct.
