PM sentAncient Dad.. I would also like to read the carb setup pdf please.
Ahhh, right. I knew they went to and from Alternator or AC - but now it makes sense. Thank you so much. I'm starting to see the light again, after a couple of days in the wiring doldrums. Cheers.DY = Dynamo (white wire coming from alternator)
SE = Selenium (Yellow wire to the selenium rectifier/alternator.
A common modification is just to tie these together and eliminate the switched component of this - when combined with a modern rec/reg unit. This improves the low speed charging. It looks like they may have been taped together?
That "board" also belongs in the switch. When you slide the switch over to Hi beam, it automatically connects the white/yel circuit described above to bring both phases of the alternator into the charging flow.
Hello sir,There are versions with and without starter. All are 6V, so battery capacity combined with starter consumption results in small startup margin. As such there engine covers with slot for starter as well as covers without this slot. My bike (red) does not have starter. My brother's bike (gold) has starter from the factory.
The OFF switch is on key. The unit pointed by AncientDad is starter indeed.
Rubber gaskets for carbs expands while contacting modern fuels. Use hot water bath to shrink them to the original size. Otherwise bowl assembly will be tricky.
That's not going to work. Given the number of "CB125" models over the years, it's not surprising to find these packing sets mislabeled. You're looking for part number 16010-304-305 On that side of the pond, CMSNL and David Silver Spares both show them in stock (although less expensive at CMSNL)Hello sir,
I just ordered some carb gaskets from ebay. They arrived but they are too big. You mentioned shrinking with hot water. Do you think that would work in this case? The original is on the left.
Your current Projects and Builds thread encompasses everything you do on your bike project.So, moderators, I have a question regarding turn signals. Do I have to keep posting on this thread? Or can I start a new one?
..Cheers for that. Mine is a 6v battery. I will check all the grounds very thoroughly.There is no real purpose to “jump the flasher to protect it” god, the unnecessary “hacks” in those videos have probably led to more dead bikes and rotting projects than anything else.
Do not overcomplicate this.
Switched 12v hot runs to the flasher (black)
Grey comes out of the flasher and to the left switch
Orange and light blue go out from the switch to their respective sides.
Signals and bulbs are grounded
One of your bulbs isn’t grounded on the side that’s not flashing,
..sounds like I might be doing the same very soon, merci beaucoup.I had to run dedicated grounds from my rear turn signal housings directly to the frame to get them flashing properly. The stock grounding schema on these bikes is substandard at best.
I checked the ohm resistance on each turn signal lamp - All gave readings over 1. (1.2 to 1.6) So this means I have to find better grounds? Right?I had to run dedicated grounds from my rear turn signal housings directly to the frame to get them flashing properly. The stock grounding schema on these bikes is substandard at best.
What points were you measuring resistance from? That’s not ideal resistance but it’s not crazy.I checked the ohm resistance on each turn signal lamp - All gave readings over 1. (1.2 to 1.6) So this means I have to find better grounds? Right?
All factory lamps. I was measuring from the black pos at the rear fender to ground screw on lamp. All 6v bulbs. Will clean contacts tomorrow. Thank you for your advice.What points were you measuring resistance from? That’s not ideal resistance but it’s not crazy.
Another complicating factor is we have no idea if you’re operating with factory signals or not. Assuming that you are, it may be as simple as just cleaning up the bullet connects for those grounds. Should be a shared 4-way female bullet around the taillight/rear fender with a bunch of green wires.
Also verify positive voltage at the bulb and that nobody put a 12v bulb in that signal.
Hello John, rubber gasket boilign bath is working with gaskets which are enlarged due to contact with fuel (alcohol content improve penetration). If the gasket is new and dry there should be no significant size reduction.Hello sir,
Ha!, my name is Dave! ..no, it didn't work. I'm going to have to order the expensive ones from CSMNL. "Buy cheap - buy twice" I should know better really. ...Hello John, rubber gasket boilign bath is working with gaskets which are enlarged due to contact with fuel (alcohol content improve penetration). If the gasket is new and dry there should be no significant size reduction.
Sorry for late reply, I was out of comp.
Check David Silver Spares as well.Ha!, my name is Dave! ..no, it didn't work. I'm going to have to order the expensive ones from CSMNL. "Buy cheap - buy twice" I should know better really. ...
..thank you Boddy. I think you're right there. Sage advice. - (Also I like the front suspension boots on your bike - are they aftermarket?)Your starter cable was disconnected because the red/yellow wire in the switch was likely grounding on the handle bars and running the starter all the time. If it was me, I would try the electric start to see if turns over and also if the clutch on the starter sprocket functions properly. If you hear strange noise when operating the starter then disassemble and check the parts.
Yay!Hook the carbs up and hit the starter button. If it works, great - if it doesn't, kick it.
They are the original boots from 1971, still in decent shape.(Also I like the front suspension boots on your bike - are they aftermarket?)
Hello Dave,Lemon Update:
So I think I've sorted the indicators and the niggly wiring and switch stuff. So I'm moving on. - I've got two things to do before I can attempt a start.
1) Put the cleaned and serviced carbs back on. I will need to check how long each piece of fuel line is and cut new sections - (I have new fuel line) - then fuel tank back on and hook it up - (with new petcock). One of things that had me thinking was how does the throttle cable route under the fuel tank? Left side? Right side? I'll probably look at the photos i took when i got the bike. See if I can see where it emerges.
2) I have an electric starter (this being the French CB125 K5 twin with starter) it was disconnected when I got the bike - so now the question will be should I try to start it with the starter for the first start - or should I use the kickstarter? The thing that bothers me about that is - I've not had the starter off to check it - it may be ****** - Also I've not had the left crankcase cover off yet either - to check the condition of the starter chain / sprocket.
I'm eager to try and start the bugger now that I've addressed the dodgy wiring / installed a new battery / replaced the handlebar Start and Dimmer switch - it might just go off all sweet and beautiful. First time. ..
OR..
I might wish that I had done option number two. Properly. Like a grown up.
What would you do?
Merci.Hello Dave,
concerning throttle cable, please, note, that throttle cable is splitted for two separate carbs. It is slightly assymetric. Longer end goes to the right carb slider. It runs from steering wheel throttle through cable holder on steering wheel to maintain minimal cable bending. Then it goes back on the left side of the frame. Cable routing (throttle and front brake) is shown in manual.
I would try to test starter from the battery (if insulation is good and there is continuity on coils. For kickstarting do not pull clutch. Engine will run faster if You will try start this without a kick, by selecting second gear and using momentum to start the motor.
Starter - you mean take it off and test it on the bench? Makes sense.
And by starting it in gear - with momentum - do you mean the old run and jump start?
Slight incline. Second gear. Clutch in… BANZAI!!
All open pipes (oil breather, carb drains, battery breather) are going to the slot located below the toolbox.Morning you beautiful people.
So just now I re-routed the throttle cable - the consensus being that around the steering column and to the left - was the way to go. So here's a little pic of that. Lovely, thank you. The throttle snaps back a lot better now than before, so it feels right.
While I'm here I have another question.. Where is the breather pipe supposed to go? Does it just disappear down the frame to fresh air?
