nabs
my D-cell powered strobe like arrived yesterday but unfortunately does not work so I will not be able to check the timing until I can arrange a replacement.
In the meantime I have had a go at resolving the rich idle. The stock slow jet is a #35 and although Honda did once upon a time offer a number #32 it seems to be unavailable now.
I was able to find an alternative set of keihin jets which are available as #31 and #33, but the need to be modified to fit
The jets are the right length and the screw thread in the same place as the stock jets, but the head, thread and emulsion tube are all wider than stock + the thread pitch is 0.75mm rather than 0.6. I was able to find the required 3.5mm/0.6 pitch die on ebay for a few quid.
the only tricky bit is the tube which needs to be filed down from 2.5mm diameter to 2mm as there is only just enough material to do this. I managed this by (engineers look away now) putting the jet in the jaws of my battery powered drill driver and gradually filing the outside of the tube.
It is then just a matter of reducing the diameter of the head, removing the old threads and recutting the new ones . I broke the first jet while doing the adjustments but luckily I had a spare (they are only £3 each), and the next two attempts were ok.
I could not get an idle with the #31 but the idle is good with #33 albeit still a bit rich I think. Here is a new spark plug after idling for a few minutes - no longer covered in soot, but still black
irritatingly I can't find a #32 which I think would be better. It is still rough at low revs but I am begining to think the may be the best I can get it. Anything else I can try?
