The purpose of the Black Ball in the lower case
fxray
Central Illinois
Looking through the forum, there seems to be a lot of questions about the black sealing ball in the 350 engines. Several people have pointed out where it goes, but there still seem to be questions as to why it is there in the first place. I have been working on my SL350 recently and took some pictures that may help explain the mystery to the newer folks.
The RH side of the lower crankcase is where the oil pump is mounted. Here are the three mounting bolt holes surrounding the port to accept the output of the pump. (The three most central holes shown here.)
On the bottom of the pump body, there is a screen-covered intake port that is submerged in the oil in the sump. Like any pump, this piston pump operates by creating an increasing volume (piston is withdrawn from the pump body) at its input port and decreasing volume (piston is pushed into the pump body) at its output port.
Increased volume at the input port creates a vacuum, so atmospheric pressure acting on the oil in the wet sump pushes the oil into the input port.
When the piston is pushed back into the pump body, a check valve inside the pump prevents the oil from flowing back out the inlet port, and the oil is pushed out of the pump's outlet port. It flows into the odd shaped hole cast into the side of the lower crankcase.
From there, the oil flows upward through a drilled hole to the port shown directly above the pump body in the above picture. These two passages in the side of the lower crankcase are interconnected via the drilled hole:
That upper port directs all of the oil output from the pump into the RH side cover of the engine and into the centrifugal oil filter contained therein. After the oil filter, there are other passages to direct the oil as needed throughout the engine.
The only way to drill a hole connecting those two ports is by drilling down through the crankshaft bore that is directly above the two ports. Note that the upper part of this drilled hole is enlarged to create a counterbore, sort of like a little shelf inside the drilled hole.
That is where the black ball comes into the picture:
It fits snugly into the enlarged upper part of the drilled hole.
. . . and then is pushed down into the hole by you, the assembler, until it sits on that counterbore.
Once the crankshaft is installed, the little black ball is trapped there until the next person opens up the engine, hopefully far into the distant future.
This is a good example of what is called a process hole. That means that some of the hole is not intended to be used but has to be there in order to drill the rest of the hole. Once in place, the part of the hole that is not needed has to be blanked or sealed off.
Hope this helps explain the reason for the infamous black ball.
Ray
Perfect explanation with excellent pictures.
One thing to note is the oil sump port to the pump. I found casting slag blocking @25% of the opening when I did the CL engine
And interestingly enough, the 450 lower case does not have that port to the pump cavity, which is why Jay recently mentioned drilling a 1/4" hole there.
It's clever, simple solutions to what could be complex problems that makes me stick with Honda bikes. The company seems to respect its engineers.
very interesting. I was definitely one of those members that spurred the creation of this thread. Glad to know the reason of that black enigma!
Thanks Ray. I could see how it sometimes gets left out due to the crank bearing also blocking that process hole.
I saw the rubber ball in my case, but didn't see one on the other end with a similar hole and was worried I might have lost it.
Now I know there only the one, so thank you.
As I tear into the bottom end of my 350, I find the mentioned "black ball". My question is, all references to the ball seemed to be rubber. Mine is either very hard or made from plastic. Should I plan to replace it with a newer softer one?
It's a very hard rubber like plastic, yours should be fine. It's not a wear item.
Could you provide a link to what Jay did if it was talked about?
I can't recall the thread it was in, but it's the same area as this picture from post #3 in this thread. The 350 has this passage and the 450 does not
I'm sure @Jays100 would be happy to share a picture of what he did.
Is it just a simple 1/4 inch hole that replicates the passage in the 350 engine? If so, I think I can follow that.
For the 450, I recommend adding 3@ 6mm/1/4" holes in that area but even with just one, it's a supply improvement to the pump (whatever one you have).
Hope I don't have to get that deep into the side/bottom end of my CL450, but if I do this is great to know
