ballbearian
I have only one statement.It's OK, you can admit it here. You might like working on the bike almost more than riding it.
I don't want a pickle.....
Cuz it won't help you ride your motorsickle.I don't want a pickle.....
Now THAT takes me back.I don't want a pickle.....
I should have posted a pic of my cut gasket. Those are the old OEM from the rebuild on the right and the cheapy (cheaper than usual NE) one that leaked.Are you cutting out the circles using an x-acto knife or something along those lines? Looks pretty good.
I've cut a few gaskets in a pinch and with small circles I think I tried to rotate the material rather than the blade. What's your method?
It was hard to accurately measure the used OEM and Honda doesn't provide a spec but it was about .025". I had some good sheet that was .030 so I figured it would compress some and still be about right where I set the clearance with the torqued NE gasket originally.The gasket looks good ballbearian !
I like using OEM gaskets when I can still get one that's pliable,as the stock Honda gasket has the correct clearance so I don't need to re-shim the camshaft clearance.
The OEM gaskets are a very tough material;I've removed,tightened-up and reinstalled the cam covers a few times using the same previously 'new' OEM gaskets.It was hard to accurately measure the used OEM and Honda doesn't provide a spec but it was about .025". I had some good sheet that was .030 so I figured it would compress some and still be about right where I set the clearance with the torqued NE gasket originally.
Who knows, they were the only ones did come off cleanly but decided to use all new but I did keep them for reference.The OEM gaskets are a very tough material;I've removed,tightened-up and reinstalled the cam covers a few times using the same previously 'new' OEM gaskets.
I have had Such a horrible job scraping original,hardened by heat and age top-end gaskets off the CB350's cam cases.
That's cool, if it did the 8mm holes it would be perfect if near enough to the edges. Pre drilled wood blocks for holes further in could work I guess.For cutting gaskets I have a bunch of old-school nail scissors that I took when we cleaned out my grandmother's apartment. Heavy duty toe nail scissors work great. For making the holes take a look at a tool like the one here -
Multi-size leather punch
I have one of these that I found in a toolbox at my father's house.
I need to wash the oil off, I think I may still have a leak but it was a nice 20 miler and a stop at an old cemetery where this monument to a former ballbearian, no doubt, stood.View attachment 33727
Indeed. He likely loaded lead balls into his rifle as a Civil War infantryman out of Pennsylvania (link).I need to wash the oil off, I think I may still have a leak but it was a nice 20 miler and a stop at an old cemetery where this monument to a former ballbearian, no doubt, stood.
Amazing Brody, I'd never have thought to search that. It is pretty imposing, more like artillery ordinance, but hey, he lived pretty long and had plenty of dreams, no doubt.Indeed. He likely loaded lead balls into his rifle as a Civil War infantryman out of Pennsylvania (link).
It's great to hear you're back in the saddle.I must say that short test ride was just glorious.
Not here in this thread of course, but if you copy it to a new post in the Tips and Tricks section of Technical Stuff I'll pin it.(maybe this step by step explanation should be sticky @ancientdad)
I replaced the Orings on the rocker shafts but that wasn't it. I pressured washed off the oil on a hot day and did a short test ride. It still leaked right at the head stud of the rocker box to top of head joint. I could see the leak like the spit bubbles that little babies make at the gasket line right there (center of pic).
I will try to re-torque the head nuts, lost cause? Who gets away with that? It's worth a try, right?
I must say that short test ride was just glorious. First ride since dodging death. As Oliver Twist said, "Please Sir, can I have some more?"
I think your original post was relevant, since the head is torqued through the rocker cover on this motor.Sorry, I did not understand it was the rocker cover....
Jensen must've edited out the link, or it somehow disappeared. I was going to review it before I attempt a retorque.Not here in this thread of course, but if you copy it to a new post in the Tips and Tricks section of Technical Stuff I'll pin it.
Actually, I don't think he did it, probably forgot. But it does look like he edited out the explanation in his post above.Jensen must've edited out the link, or it somehow disappeared. I was going to review it before I attempt a retorque.
You're right about the knock pins. Probably not it, but I just noticed (if the picture is accurate) that the cam cover gasket is different on the right front side compared to the left. Could the gasket be flipped? You know me, haven't touched a 350 in a long time.Here is a better pic of the location of the small leak, marked with a red sharpie.
I lifted the tank to access all the head nuts and gave them all just a tiny nudge with a short end wrench. A double nudge on the stud right at the leak and it was slightly looser and easier to add torque to. I think I got a better feel with the small wrench than the long 3/8 drive torque wrench. It maybe north of 20ft/lbs. now but I'm not worried, it felt good.
Possibilities for the cause of the leak include, a bad gasket, a ding in the mating surfaces, or (a long shot) there is a knock pin that is too long or not seated all the way. I can't remember for sure but knock pins should only be on the intake side of the top of the head.
Given that I put the cam bearing gasket on backwards, I'd say that is a possibility. Double Homer!You're right about the knock pins. Probably not it, but I just noticed (if the picture is accurate) that the cam cover gasket is different on the right front side compared to the left. Could the gasket be flipped? You know me, haven't touched a 350 in a long time.
He must be getting them from the same or similar source as the OEM-style taillight assembly for an SL100 I bought from an eBay seller, it fell apart in the first 200 miles or less. Spotwelds broke, tab for the threaded screw hole for the lens screw bent, came apart on the road. Ended up buying a good used OEM taillight and it's been on there since.Also, a defect in the nice looking Scrambler Cycle repop signal lamps. the bracket that holds the socket has no rubber damping and is too lightly spot welded. I've drilled and screwed the broken spot weld and one bracket broke and had to be replaced with a DIY metal siding scrap.
Next step is to wrap inner tube rubber around the sockets and use some Phillips heavy duty 1156 bulbs.
No problems from the same lamps used in front.
Great looks and price but the brackets need help.
I've had similar issues on those CEV tail lamp assemblies for mopeds. You know exactly which ones I'm talking about! The repros look good but had the cheapest socket retainers for the bulbs. Constantly blew bulbs until I hacked up something enough to make it work. Then finally completely split apart from vibration about 3 years later.A slower leak means the new cam box OEM gasket replacement will wait until I get more miles on this oil. The valve clearances didn't change (I checked) after the minor retorque.
It runs good and is pretty quick with it's 38 tooth rear sprocket. Stock CL, whereas the CB's have 36's. Natural environment for a small bike is windy Clopper Road.
This thing just eats rear turn signal bulbs. 4 so far in it's 55 mile grand total of post redemption milage. 350's are known for vibration but it shakes it's booty like a cheerleader on spring break.
The turn signals, do you use them?Are the OEM turn signal lights hard to find? Maybe good used ones on eBay? I have run up almost 13,000 miles on my 1971 CL350K3 and I don't believe I have ever had to replace a turn signal bulb.
Absolutely, but only when I'm about to turn or switch lanes. Otherwise, I shut them off to conserve blinker juice.The turn signals, do you use them?
(Sorry, couldn't resist)![]()
Sorry for my late chime about blinkers. Believe it or not you can actually run LED bulbs in two of four turn signals without changing to an LED flasher! Yep! Been there done that.That'll teach those rattly bulb eating sockets. I probably should not use my blinkers, I am always forgetting to turn them off. Wasting all that blinker juice and confusing people driving behind me.
Maybe later, that oil leak bugs me. I'll have to fix that.You've got it sorted enough now to sell it.
I could, but if I can gloat over fixing the death rattle, that would be cool too.Sorry for my late chime about blinkers. Believe it or not you can actually run LED bulbs in two of four turn signals without changing to an LED flasher! Yep! Been there done that.
Put LED's in vibrating turn signal housings if regular filament bulbs keep failing.
Remove VIN tag and slide a good frame under it.
Just because it has a title does not make it worth repair. that frame will never be safe structurally no matter how much effort you put into patching it up.
I just checked my float level with the muzzleloader cleaning fitting (in 6 x .75mm thread). Worked like a charm and the level was just about 4mm below the rim edge. Perfect, now I can consider other carb issues.
Thank you for interest and reading. I got a lot of satisfaction from the whole process.Wow - I just read through the whole discussion, what a journey! Any further updates since September? Thanks, Steve
And do not use that BP8ES with the Projected tip.First start of the season, a month ago, did not do well, left header not heating much and a loud back fire.
Eventually, out of the rain, in the garage, I found fouled plugs and started checking causes. The re-used ND plugs had proper low resistance but the caps that were on the cheap replacement coils were non resistor type. I haven’t yet checked the coils but realized I was low on new plugs and many of the NGK B8ES plugs I did have showed zero continuity.
I resolved to get new NGK LB05F 5ohm caps and a good stash of plugs. Since the NGK non resistor plugs are often fakes or just poor, I decided to go with the ND plugs specified in the 73 K5 owner’s manual.
