TomatoThePotato
Hey guys, I was hoping you guys could help me out here.
Recently, I went to get my bike safetied and the mechanic had failed me for two reasons.
A. My brake lever did not return to its position when let go causing the front brake to be slightly engaged.
B. My throttle had a bit of a dead-zone and would not engage until turned maybe an additional 30 degrees.
For this thread, I’ll only talk about A. There is another thread about B. If you guys are able to help me on that as well.
Mechanic said that the lever didn’t return back to its original state which would cause the brake to still be slightly engaged. I knew this was an issue but when I test drove it, it never was a problem and I never felt any resistance so I didn’t think much of it.
This picture above, you can see how much of it was still pulled when i left off. Now here’s what I think the issue is. When I had swapped my handle bars, i had replaced all of my cables on this bike except for the front brake cable as I could not find it at all. So I tried to reuse the original one that came with the tall original handlebars and placed some engine oil inside to loosen it up - which it did. Though I think it wasn’t enough to fix it. Now I’m thinking I continue to look for a replacement brake cable. The mechanic however stated that my front brakes are entirely seized from the inside, I was confused because i had opened the drums, replaced the shoes and put anti seize on anything that needed it to ensure nothing would get stuck or i have trouble removing parts if i ever have to. I am not sure what might be the issue.
I believe I mentioned this before and someone had mentioned the dots did not allign on the lever, I did fix this but the issue was still there.
Updated pic^
So yes, those are my issues. I may already have a lead on a replacement brake cable, so I am looking into that at the moment. But is there any other reason why this lever is not going back to its original position ? Are the brakes being seized really true or was the mechanic just trying to get this bike (that could possibly be a death trap lol) off his hands? All support is appreciated.
Updated pic^
