ballbearian
All the disembodied can do is mind games, flattery mostly, unless you invite them in.... ah screw it, just go the whole hog and pull out the ouija board![]()
There definitely seems to be variations in LED quality. I've had some BA7's that didn't last long (I did have lack of ground and rectifier issues though) but have also got some newer different ones that seem to be holding up well. The thing I like is with the bright white 5K kelvin ones even my old semi dingy gauges are much crisper. Next purchase, will try Sparcksmoto ones, hopefully better quality than amazon whatevers.No room for a ouija board on board, and I'd prefer no evil spirits get involved.
I don't ride at night unless I get caught out later than I plan to be, so it really isn't an issue. But I think I'll move that bulb to the opposite side, then at least the tach side (the one that will work correctly) will be the readable one. The last illumination LEDs I've used came with my refurbed 450 gauges bought from an HT member and they didn't last, they were apparently vibration victims.
I see what you're saying about the light.It's not coming through the gauge face, it's coming around it at the edges. And I'm not taking that gauge apart since I can't use the reverse-rotating speedo with my speedo drive.
Notice how the speedo needle moves the opposite direction on that gauge? So does the internal drive, which means connecting my cable to it will result in turning the speedo backwards. I'll be looking for a later gauge that both needles move in the same direction like the Bomber gauges.I see what you're saying about the light.
Please explain "reverse-rotating speedo" ?
Ohhh..Notice how the speedo needle moves the opposite direction on that gauge? So does the internal drive, which means connecting my cable to it will result in turning the speedo backwards. I'll be looking for a later gauge that both needles move in the same direction like the Bomber gauges.
I know, and I looked for a reversal device and they do make them but what I found was only for cars. Bill Silver said the CB77 speedo drive unit would work as far as rotation but he was not sure if it would work with the 450 axle and hub without modification. The simpler way to go, albeit probably more expensive, would be to find a later CB77 gauge with both needles going the same direction like the Bomber gauges. That's down the road, for now I'm not going to agonize over it.Dang. If only one could flip rotation at the wheel end driver easily.
All the cables I've used are Honda-style aftermarket pieces so the barrel ends are the same as original. I've just never soldered a cable end before and with a vacation coming soon I don't want to do anything that won't be reliable. After we're back I'll look into combining some of the different length pieces and try making one of my own I guess, I really don't have anything to lose.Can you cut off the end of the throttle cable at the twist grip, bird cage the wire, and solder on a new barrel? Would that make the cable too short, or do you have enough to work with? Somebody said that Flanders Cable is gone, but I think they are just having website issues. You can probably still call them on the phone. Do you happen to have a picture of the cable end that attaches to the throttle sleeve?
Just don't do anything on your vacation where you have to evade the cops and you'll probably be fine without that last bit of WOT.All the cables I've used are Honda-style aftermarket pieces so the barrel ends are the same as original. I've just never soldered a cable end before and with a vacation coming soon I don't want to do anything that won't be reliable. After we're back I'll look into combining some of the different length pieces and try making one of my own I guess, I really don't have anything to lose.
LOL, they'd just follow the noise... and it isn't like I have a Hayabusa that can outrun even a helicopter sometimes.Just don't do anything on your vacation where you have to evade the cops and you'll probably be fine without that last bit of WOT.![]()
During one of our lengthy phone calls when I told him about the thought I came up with to use an o-ring, I didn't give it another thought after that. Next time he sent me some parts he included a few of those rings he made on his lathe. It was a great idea, and that's the kind of guy he is.Chris's advancer ring is a neat idea. Sounds like it would take care of any slop in the springs for a more accurate static adjustment that way.
You have well trained "hand, eye" coordination and don't need the popsickle sticks or hibachi skewers for carb synching.
I've used tiny zip ties to help keep the indicator boot on that bezel nut with the original rubber boot, but I like the Uxcel terminal boots best now.
That's pretty interesting and adds credibility to Ferris Bueller's Day Off.what reaction will the speedo give while rotating backwards? The answer is, despite not having a trip meter anymore, I can use the odometer as it counts the miles removed from the current total miles on the speedo
That's good news. I assume you didn't attempt to lock the rear wheel at higher speeds. =)But the upside is I can now lock the rear brake at low speed, something I wasn't able to do before, and I'll be able to brake harder and finish getting the shoes bedded into the rear drum now as well.
LOLThat's pretty interesting and adds credibility to Ferris Bueller's Day Off.
No need, I have an excellent front brake.That's good news. I assume you didn't attempt to lock the rear wheel at higher speeds. =)
If ballbearian mentioned his own useage of the Kable Ease I would certainly like a link to it. I know lubing cables can make a big difference, my son's clutch cable on his cb350 for example. His action was very heavy/stiff compared to my clutch and after going over everything the cable was the last on the list. I never would have believed it but after a clean and lube it was night and day. This is what we used but I would like to try the Kable Ease as well.And kudos to @ballbearian for his suggestion of favorite cable lube Kable-ease, that stuff really works. I've always been hesitant to lube new or good cables unless they absolutely needed it, because I've had bad results in the past with it working fine for a while but then getting worse later for some reason. The clutch cable on my 450 only has 3600 miles on it but has always pulled a bit stiff, and the engine has stock clutch springs and a well-lubed lifter mechanism so it made me wonder why, but this stuff improved the pull significantly and it's a lot nicer now.
Thanks for that. I will order some, and for starters use it on a mid 80's Bridgestone 12 speed I am currently restoring.It looks to have some graphite in it, the liquid is a blackish color. I'm amazed at the difference. It didn't feel like much at first but after it sat for a while and (I think) soaked further down the length of the cable, it got better and then after today's short ride up to full temperature it pulls about 40% better. I'm very happy, it will ease the load on my left hand while riding twisties with lots of shifts.
Walmart lists it but they're out of stock, and I suspect the price shown ($3.99) was before more greedflation set in. Oh, and the search result lists the tube as "12 ounces" when in fact, it's 1/2 oz
I actually have this same exact headlight for my CL450. With the parking light and all. I was curious about the adjustment screw. Did you ever figure anything out? Also, I am very curious to see what you have in store for the parking light.![]()
I'm going to try to sneak the (non-functional) side adjustment screw in the hole to fill it, not sure if it will clear the outer ring of the headlight but I'll try.
You are supposed to shake it well to get the graphite into suspension before you apply it. I was shown it by my old boss to use on speedo cables especially.It looks to have some graphite in it, the liquid is a blackish color. I'm amazed at the difference. It didn't feel like much at first but after it sat for a while and (I think) soaked further down the length of the cable, it got better and then after today's short ride up to full temperature it pulls about 40% better. I'm very happy, it will ease the load on my left hand while riding twisties with lots of shifts.
I suspected as much once I saw the look of it, so I did shake it vigorously before dribbling into my cardboard funnel. Well, the Kable-Ease, not me.You are supposed to shake it well to get the graphite into suspension before you apply it. I was shown it by my old boss to use on speedo cables especially.
Can't use it without bending or cutting it shorter, the headlight glass and outer metal rim are enough larger than the original that the screw won't fit past the assembly. It wouldn't be functional anyway since the headlight is held in the rim by 4 "W" spring retainer clips, but it would be nice to have one in the open hole in the rim. Oh well, that's what happens sometimes when you do custom stuff.I actually have this same exact headlight for my CL450. With the parking light and all. I was curious about the adjustment screw. Did you ever figure anything out?
Nothing exotic, I just ran it off switched power through the old CB77 headlight switch with the new non-original "chicken-head" knob on it. It's independent from the headlight, so I can turn it on or off anytime the key is turned on.Also, I am very curious to see what you have in store for the parking light.
On a Brit bike, that's called a pilot light or pilot lamp. In daylight, it lights up the bucket enough to make it look like you are complying with the unelected beaurocrat's desire for a daytime headlight, yet it is a low wattage bulb. It helps a weak charging system keep the battery charged properly.Nothing exotic, I just ran it off switched power through the old CB77 headlight switch with a new non-original "chicken-head" knob on it. It's independent from the headlight, so I can turn it on or off anytime the key is turned on.
Good to know, I wondered how it was described from the Brit or Euro perspective. When I put about 15 miles on the bike a few days ago, I turned the headlight off when going through my neighborhood at low rpm and turned it on when I got to the highway. Doesn't hurt that my little 4 amp lithium ion battery holds 13.3v at rest.On a Brit bike, that's called a pilot light or pilot lamp. In daylight, it lights up the bucket enough to make it look like you are complying with the unelected beaurocrat's desire for a daytime headlight, yet it is a low wattage bulb. It helps a weak charging system keep the battery charged properly.
Until the battery went dead, LOL. Then either the bike completely hides, like my XL250 with a flat tire on the north end of a major highway in north Tampa when I was in high school (and I shoved it into the bushes next to a fence line on that then-little-traveled section of the road late at night), or it's defenseless with many cars going by not seeing it until they're nearly upon it.I always thought that would just make it easier for thieves looking for bikes to steal in the dark.![]()
The main harness on my bike has one female green multi-connector and I might have to do something myself if I want to use the high beam indicator in the newer gauge I have coming from @DavomotoLast time I checked, I actually don’t have an extra female green ground connector to plug the parking light into. I think I had to sacrifice pulling the green wire from the high beam connector to make room.
Yes, and somewhere in my less-than-organized mess I have one for ground just like that (except green, of course) but I couldn't find it the other day when I looked for it. But if you saw my garage you'd know why.Honda used these a lot when an extra connection was needed.
It will turn up right after you make a new one!Yes, and somewhere in my less-than-organized mess I have one for ground just like that (except green, of course) but I couldn't find it the other day when I looked for it. But if you saw my garage you'd know why.
Yes, I have at least one additional ground to the frame over the stock harness and the ground from the gauge is plugged into the multi-connector green in the main harness. I just wish the gauge would get here... right now it's trapped in the black hole that is (often) the Jacksonville post office hub. Hopefully it doesn't get sent back to the west coast before finally being delivered like my t-shirt did a few years ago when Jim shipped it to me.The high beam indicator that came in the CB77 has only the blue wire, the dash lights only a brown wire and the neutral light the green with red stripe and a black wire. There is a green wire attached to the base of the speedo unit that attaches to ground and the lights, neutral excepted use the base as ground. A Dede aged ground wire from frame to somew in the headlight shell is always a good idea.
It was known, but I wouldn't have expected them to ship it with loose glass pieces still falling out into the box and bubble wrap.If the glass broke from poor packing, I'd let the seller know.
It's not completely hard, but it's stuck on the other gauge right under the crimp ring at the top and I can't soak it in anything without soaking the upper part of the gauge with it. I'm just concerned with ruining it trying to remove it from the one to put it on the other. And this is more like foam rubber so I'm not sure how wintergreen oil and rubbing alcohol would work on it, or if it would soften it too much.Is the rubber ring hard and brittle? Have you tried soaking in rubbing alcohol and wintergreen oil? Stinks but I had good luck with the air cleaner boot on my S90 to get it soften up.
