RobMan
Had a great welcome to the forum and wanted to move my restoration/resurrection progress to the proper location as @ancientdad suggested. I am sure there will times I wish I could lay hands on the beast and holler "Heal" and that will be when I reach out to all the good people here! Recap is I had finished bringing a 65 Honda S90 back to life last summer and started having a serious itch for a winter project. Saw a 72 CB450 post on Craigslist and from the pics it needed a lot of love. Bike had been sitting in a shed since the 80's and obviously had a major incident and engine appeared to be sized as well. See my welcome thread for a lot of great discussion, observation and advice from many members.
Here are a couple of images from the Craigslist add. Note the dent in the tank and crash bar bent back on the left as well as the broken chain.
After I got it home pulled the the drive cover I was able to get the chain loose where it was jammed up and was then able to kick the engine over and and it has compression!
Pulled the engine yesterday and got it on a hand truck and after sealing the crankcase vent, intake and exhaust ports with extra thick gasket material I did as as @wentwest suggested I rolled it over to an area that wouldn't upset the wife and I sprayed it down with engine de-greaser and cranked up the pressure washer.
After a closer examination of the bike after pulling the engine and and cleaning it I can safely say it "was rode hard and put up wet". The engine has been disassembled at one time and all the fasteners were probably thrown in a coffee can as many of them look like they are in the wrong locations and are using washers were it didn't call for one. Also note the marked bolt location, head is gone, been drilled and although I can't see for sure I bet there is the tip of an easy out in there. I am hoping I can just pull the cases apart off the bolt shank later and remove it with time, PB Blaster and a good pair of vice grips.
Anyway this is it up this point. I am torn between starting the engine tear down or starting breaking the frame down check the forks and running gear. Oh well I have other chores to do at the moment so will decide later.
