Thank you - I'm either being very daft or there is something very strange indeed going on with my 198cc motor:But do you know if those pistons are stock bore before ordering 2nd over pistons? Your pics won't enlarge so the scuffing in the cylinders is difficult to see, though I can see a bit of it in the second pic. No rings are stuck? Also, note the cam chain wear in the head near the tensioner shaft
That is the only conclusion I can come to, here are the barrels from my CB200:Wow, that's a major overbore. I wonder if they're SOHC CB750 pistons (61mm bore, 63mm stroke). I've not heard of anyone doing it but they're the only Honda piston that comes to mind with that size, though there may well be others.
I'd be looking for a set of stock cylinders and pistons. And check the rods closely, if that engine was abused heavily with that large an overbore the big end rod bearings could have taken a beating.
It is a mystery. I’m certain the motor has been apart previously (not least when someone bored it to 240cc) - the fasteners all came apart easily and certainly had not been in place for nearly 50 years. I can’t really think of an explanation for the sprocket carrier failing.I wonder what on earth caused the cam carrier to fail like that, seems most unusual. Do you think that the engine has been apart before, maybe someone had a struggle with the endless chain / camshaft / sprocket jigsaw puzzle, overtightened a bolt before the sprocket was properly in place ?
( A possible bodge - get the sprocket welded to the cam, then use a rivet link in the cam chain )
EDIT I also notice the usual CB200 cam chain wear marks in the cylinder head tunnel. New chain might be in order.
People have tried welding that flange in the past meeting with failure every time.It is a mystery. I’m certain the motor has been apart previously (not least when someone bored it to 240cc) - the fasteners all came apart easily and certainly had not been in place for nearly 50 years. I can’t really think of an explanation for the sprocket carrier failing.
I’m not sure that part would be easy to weld - it looks like a cast item. I’ve bitten the bullet and bought a second hand camshaft for £170 (delivered). We’ll see how it goes back together in a week or so.
Alan![]()
Thank you for that. In that case I take it this isn't an uncommon occurrence?People have tried welding that flange in the past meeting with failure every time.
Wonderful. I can see that thread is about a decade old. I wonder whether it was inspired my my bike - or perhaps the other way round? I have no idea when the 240cc bore appeared, on SDV588R, it could have been decades ago. We may have identified the pistons as from a CB750F2, but that doesn't help a great deal as it is going back to standard next week.I wasn't paying attention last night, missed the part about the vast over bore. It has been reported here ( or the other place ) before, UK member with the handle 'Brush' had a CB200 with this modification. It blew up and he ended up selling it for parts - I bought a CB200 rear grab handle from him.
Yawn CB200 cafe racer
Regarding that flange - if welding isn't an option, are there any other solutions ? The 175 cam sprockets are simply pressed into position, if I've read an earlier past by Simo correctly.
Looks great .hello from NorwichI have become somewhat addicted to older project cars and motorcycles, in recent years there have been quite a few Volvos (several 240s and the Amazon I still use most days) and motorcycles from Triumph, Suzuki, CCM and Honda. I tend to buy unfinished projects that someone has given up on, like this 1984 Goldwing that was a non-runner the PO had given up on, but 5 months later is a nice bike that I’ll keep:
Having more or less ‘finished’ (projects are rarely ever completely finished) the Goldwing I started looking for something else interesting. This 1977 Honda CB200 was advertised on eBay as a runner but needing ‘a few jobs to finish’:
The seller and I agreed a price of £1,500 over the telephone, then Bob (the dog) and I hitched up the bike trailer early this morning to collect it in Surrey (2 hours drive away). The PO seemed a genuine chap, he was new to motorcycle projects and having spent a fortune on the bike and new parts had realised he had bitten off more than he could chew. This was exactly what I was looking for: a complete bike in need of some work (but I hope not much money) to get it to a good standard. I never attempt to get vehicles to a show standard, but always to make good useable and reliable cars and motorcycles.
It looks like the CB200 had been off the road for at least 20 years until reassembled by the penultimate PO. Being more than 40 years old it is registered as an historic vehicle and so doesn’t need a MoT test and is tax exempt. The bike looks lovely, and seems to consist of more or less original parts, except the horrible silencers (mufflers for North Americans):
The silencers are far too noisy, don’t fit properly (the kick start would hit the right hand one) and not correct at all. I have found a supplier of new copies of the originals at £300/pair; I’ll order some tomorrow.
The motorcycle came with a printed copy of the Honda workshop manual, a Haynes manual, a folder of receipts and box of useful spares. The issues that foxed the PO were a very noisy top end (sounds like a bag of nails) and poor running. If I’m fortunate the noisy top end will be fixed by adjusting the tappets and tensioning the cam chain, I’ll do those jobs tomorrow. The PO had the carburettors cleaned, but they obviously need setting up properly, once I’ve sorted out the mechanical issues with the top end that should be easy enough to fix.
I noticed a few electrical jobs that need sorting, such as the horn button doesn’t work. There will probably be a myriad of other jobs once I have a better look at the motorcycle.
So, that is episode one. I’ll have a better look at the Honda in the light of day tomorrow and make a better estimate. I hope the noisy top end will be fixed by a bit of adjustment, but if it ends up needing something more then so be it - I bought this as a project. I’ll post an update after a proper reconnaissance - and almost certainly ask for some advice on fixing the issues I find.
More to follow…
Alan
Thank you.Looks great .hello from Norwich
This can happen to perfectly healthy cylinders& rings if while parked the float bowls stick with and the petcock left open. Just overflows right into the cylinders during the night while you are in bed dreaming about tomorrow's ride.the oil I drained did smell of petrol,
Not exactly an affiliation, in fact far less than that. But yes, most of the core group here came from there.I'm guessing Hondatwins.net has an affiliation with this forum because some of the contributors seem to be the same?
Don't know about the CB200 cams but it's seen on the 350's when people use the wrong boltsThank you for that. In that case I take it this isn't an uncommon occurrence?
It is a pity because the rest of the cam (journals and lobes) appears to be in really good condition.
You're in good company Richard,I got banned from HT.net for the heinous crime of mentioning this site. Just my take on things.
EDIT Toms post arrived whilst I was typing ......
Gosh, I wish I’d known about these a few days ago - but I’ll certainly take them at £50, it will save me time getting the barrels I’ve ordered re-bored. Worcester isn’t so far away, I could drive over (with Bob the dog) and collect them at the weekend if that suited?Dug out that cylinder and pistons, still coated in oil. Gudgeon pins are actually a nice sliding fit in both the small end and the piston, don't know why I remembered otherwise.
Some photos. 50 quid + postage, if any use to you ?
Thank you (and Richard) for that explanation.Not exactly an affiliation, in fact far less than that. But yes, most of the core group here came from there.
Hi Alan, we are out and about quite a bit this weekend and again on Monday ( I'm retired ) , which is a shame since Holly and Chester, our very friendly spaniels, would love to meet Bob. I usually post items via the Parcel Force 24hr service, so the parts could be with you by Tuesday. Best to continue this conversation via the PMs on this site.Gosh, I wish I’d known about these a few days ago - but I’ll certainly take them at £50, it will save me time getting the barrels I’ve ordered re-bored. Worcester isn’t so far away, I could drive over (with Bob the dog) and collect them at the weekend if that suited?
Alan
Hi,Hi Alan, we are out and about quite a bit this weekend and again on Monday ( I'm retired ) , which is a shame since Holly and Chester, our very friendly spaniels, would love to meet Bob. I usually post items via the Parcel Force 24hr service, so the parts could be with you by Tuesday. Best to continue this conversation via the PMs on this site.
I'm wondering whether this motor has been apart fairly recently (maybe a few years) and that whomever did the work didn't get the chain tensioner set up quite right, so the chain ran a bit slack and left those scores on the cylinder head tunnel? There are some chain marks on the rubber tip that goes on the tensioner rod - which is why I'm thinking the above.I wonder what on earth caused the cam carrier to fail like that, seems most unusual. Do you think that the engine has been apart before, maybe someone had a struggle with the endless chain / camshaft / sprocket jigsaw puzzle, overtightened a bolt before the sprocket was properly in place ?
Thank you, that is interesting about the 160/175 twins using the same part.The 160 and 175 twins also use that same part, might be worth looking for a used item from one of those.
Just wondering about your crankcase top, has it been modified to get the bigger liners in ?
If you could pm me your postal address I'll get the cylinder and pistons boxed up, pistons inserted in bores for safer transit. Don't worry about payment yet, I'll send them 'on approval', return them if you don't like them.
Cheers, Richard
Hi again Richard,The 160 and 175 twins also use that same part, might be worth looking for a used item from one of those.
Cheers, Richard
Thank you.
I was thinking of that, but there isn't much room around the head with the motor in the frame. I'd like to get the covers off before pulling the engine out so I'll concentrate on that and creating enough room in my garage/gym to undertake an engine-out repair today.
I think you may see from the photo that there is no ring guide, the liners are very thin at the bottom so I think a PO has taken all the metal out of the originals rather than pressing in larger liners. For me that is a good thing as I hope the crankcase is standard.In reading your post earlier I was going to suggest flipping the barrels over to see if there was still a ring guide area in the bottom of the sleeves. That picture tells it all, as those liners are wafer thin. I can't imagine any long term running of the motor with that big of an overbore.
I replaced the CL175 Sloper rubber cam chain tensioner bit from CMSNL a few years back, as mine too had wear into the cylinder and tensioner block metal box. Possibly poor maintenance on a PO's part and never tensioning the chain per the FSM recommendations.
While you're in there now a new cam chain if available would be advisable, as they don't fair well when they are eating aluminum and metal material along with their other duties. I also soaked my crankshaft for a week + in Kerosene in a small plastic container just the right size for the assembly. There was lots of very fine aluminum bits that came out of the crankshaft bearings over the soaking time.
I guess it all depends how far and how much you want to do in the rebuild, as there have been a number of surprises already it appears.
If you had serious sludge in the centrifugal oil filter and visible goop in the bottom of the case near the oil pick up, you may have a very restricted crank oiling. How worn are your small end rod bores?I think you may see from the photo that there is no ring guide, the liners are very thin at the bottom so I think a PO has taken all the metal out of the originals rather than pressing in larger liners. For me that is a good thing as I hope the crankcase is standard.
The rubber tensioner is normally available from CSMNL, but out of stock at the moment. I can’t find another anywhere, but I think the old one will do, I’ve turned it through 180 degrees.
I hear you about the cam chain, but short of blueprinting the whole engine and gearbox I have to draw the line somewhere. I’m not planning to split the crankcases, so I’ll stick with the original cam chain and tensioner as long as I can get it all to fit properly when I put the motor back together. I am planning to flush the crankcase (with the crank in situ) with kerosene when I remove the pistons (probably tomorrow).
There are usually compromises to be made when fixing older vehicles (unless one is doing an as-new restoration).
Alan![]()
Thank you, that was very kind.Here you go out of eBay Germany. It is the correct part for a 1974-75 CB/CL200 series motor.
Honda CA CB CL SL 160 175 200 K T Chain Tensioner Timing Chain Genuine NOS | eBay
Find many great new & used options and get the best deals for Honda CA CB CL SL 160 175 200 K T Chain Tensioner Timing Chain Genuine NOS at the best online prices at eBay! Free shipping for many products!www.ebay.com
... I've sent the seller an email (in my best German - I hope he/she understands!).I would contact the seller in Germany to confirm, as it also says he won’t ship to Canada. Sometimes it is how they set up the shipping option on EBay that it shows no shipping. I have had shipments from Germany to Canada from other EBay sellers.
It would appear that the cam chain running against the tensioner or the sides of the tunnel is very common and something of a design flaw.
Thank you for that - it was so kind of you.Cylinders and pistons boxed up and Parcel Force 24 label printed, ready to go to Post Office tomorrow. I've included the two circlips that I had to remove to release the pistons from the conrods, in a jiffy bag inside one piston skirt. Not that I'm recommending re use.
Personally, with a gasket set on hand, and the engine out, I'd be wanting to split the cases out of simple curiosity, take a look at the kick start mechanism etc. Alternator rotor doesn't have to be removed, only special nut is the one retaining the oil filter spinner / primary drive sprocket, everything else ( clutch and oil pump ) is a five minute job to remove. Plus Hondabond for the case halves.
Good morning,Had a brief panic this morning when I checked the Parcel Force tracking, looked as though parcel had gone astray. However, Google Maps Streetview is a wonderful tool, and it looks as though the front door in their photo matches yours on Streetview. MR GARY ??
I was doing a couple of preparatory jobs before starting to reassemble the motor, one of which was cleaning the oil filter. I agree that it was an odd design decision to require the whole right side engine casing to be removed in order to do the job, that will have deterred many owners from carrying out proper maintenance on these motorcycles.I'd agree with that. The 200 block is slightly taller than the 175 block, also the tensioner mechanism is a different shape, resulting in the cam chain running closer to the wall even when correctly tensioned, not much room to account for lack of regular adjustments or chain wear.
Honda also made a couple of other odd choices in my view. Having to remove the entire engine side cover to get at the oil spinner is bound to have discouraged some owners from bothering with this regular cleaning task. On the other hand, it does mean that access is available to the oil pump strainer at the same time, and the revised case holds an extra 500ml of oil.
Only sending oil to the one side of the cam, relying on passages in the cam to oil the far side, seems to be a retrograde chance, as the previous system of oil pumped to both sides seemed to work perfectly well. The CB200 does have a higher capacity oil pump than the 175.
Regulars will groan at me repeating myself yet again, but back in the day I rode brand new (run in) examples of both CB175 and CB200 and found their performance more or less identical, both top speed and acceleration. As teenagers, we regularly swapped bikes to try each others. The CB200 had a much deeper exhaust note than the 175, and generally felt more 'grunty', although performance was the same.
Alan, do you have the FSM for your bike? Or are you using an aftermarket manual? If you do not have the FSM, let me know and I'll get a link from our library for you.The workshop manual says to just pull off the cover off the rotor with pliers (see pp 9), but that doesn’t seem right. Obviously I don’t want to damage anything on my 47 year old engine, so can anyone tell me how to remove the cover without breaking anything?
Alan
It is easy when you know how:Someone has already damaged the “ear” and broken them off. Once you remove the inner 6mm JIS screw there is another threaded section in there that will take a 8mm bolt? with a fine thread design. You thread that into the cap and it will bottom out inside and push it off.
To parrot BB post once your into it that far it is worth splitting the cases and seeing what going on in there. I did what your doing on my CL175 rebuild 5 years ago, top end only. My bike is a display model only, so it was never ridden.
I am just installing the motor now after correcting some previous top end damage and this time I tore the whole motor down. I found remains of a holed piston in the sump and a badly worn middle shift fork with gear damage. The bike would have never shifted correctly if not repaired.
This is the manual I have:Alan, do you have the FSM for your bike? Or are you using an aftermarket manual? If you do not have the FSM, let me know and I'll get a link from our library for you.
