Danager4792
I have seen Jim say this twice recently but have been led to believe by numerous posts over the last decade that dried up felts on the throttle shafts can contribute to high idle issues on original carbs. I have certainly pulled dried up, crumbly felts from some old carbs. So is this really not an issue and is instead a long perpetuated myth?
Personally I have found my own replacement solution for the old felts and routinely replace them when rebuilding carbs. I feel I have had more reliable results overall since doing so. Maybe I have just gotten better and more thorough rebuilding carbs as time has moved along, I dunno? I would agree that attempting to replace them requires careful work and attention to details (like orienting the plate bevels and use of correct driver and loc-tite on tiny JIS screws) so one must be diligent with their work on this. But speaking generally of complete carb rebuilds, it is truly unnecessary and a complete waste of time to replace the felt material?
In the context of Danager4792 and his troubles I would agree that adding a drop or two of oil to the throttle shafts where they enter each carb would not hurt and would be a simple and easy way to eliminate dried up felts from his list of possible problems so he could continue moving forward. Perhaps this was Jim’s point all along, if so forgive me, but I was also interested in some clarification of this long held belief for myself.
I suppose tonight I could accurately spray the throttle shafts to see if there is a change in idle. I think that would give us enough evidence to determine if it’s a myth or not.
Steve had mentioned the felt seals over the phone, for me to check them. I had brought it up to him previously. I suppose at that point I was just grasping at straws to figure out anything that could be wrong. I personally think using the strobe light to check dynamic timing will give me way more evidence/results than a few drops of oil on those seals.
