Danager4792
To verify the throttle plate orientation, check for a bevel along the top edge of the plate (there's a bevel on the bottom as well). The sloped edge on top should face towards the rear of the carb body. The purpose is to allow the plate to fit snug in the bore yet have enough clearance to rotate as the throttle is opened. The orientation of the bevel on the bottom should be facing forward for the same reason.
Also, be careful if you do need to remove the throttle plate screws. They can be difficult to remove without stripping.
Would a single drop of PB blaster on each screw be good? Or would that be too harsh of a chemical? If they’ve been removed before, hopefully they are still easy to work with.
