ballbearian
I do wish these carbs had a bowl drain screw to use the clear tube method to verify the actual float level as a 2nd witness. It's hard to unsnap the wire holder and carefully lower the bowl without spilling any, and then there is the question of how much the level would change when the float is in the gas, displacing a small amount and thus increasing the level. I guess careful experimentation with lowering the bowl could arrive at a good level when simply lowering the bowl. According to the FSM drawings, the actual level seems to be about 2mm from bowl rim, so a lowered bowl should show at least 4, maybe 5 or 6mm from rim.
Give it a shake. A leaky float would be a nice , ah ha moment.
I need to dive back in Charles flat side carb to see what's up there.
