I found a few chunks of silicone caulk in my oil filter when I cleaned it out. I since noticed some caulk that looks the same - appears to have been used on the gasket behind the tach cover. So, my guess is some squeezed out on the inside as well and found its way to the filter - that's good. I don't quite get how it would make it to the filter as I think it has to pass through the pump screen and passage in the side of the case to do so, but it did.
Problem is - I don't know where else this was done on the motor, nor do I know how many little chunks of silicone sealant are floating around inside my engine - maybe clogging oil passages - or waiting to do so.
Is there something that will cause the silicone to break down that I can add the engine oil? It might be fine, but if there is something I can do - I'd rather do it than wait for something to starve of oil and wear out quicker than needed.
