asdfqwer426
Had my 350 for about 18 years now (can't believe it's been that long!). Rebuilt the top end after a major issue about 14 years ago but for the last 7 years it hasn't run quite right and has mostly been parked in the garage. I always assumed since I had redone the engine not that many miles ago, it was fine, and I looked at EVERYTHING else. So many times. year after year. This summer I really dug into my bikes again and I finally spotted a puff of smoke coming out the side of the engine. Bad head gasket sure seemed to fit the symptoms it's had so I pulled the engine, took apart the top end, and started to clean engine parts to reassemble with new gaskets.
Issue is, I can't seem to find exactly on which studs and between which layers of the engine the two oil galley cylinder seal things are supposed to sit. Any help would be appreciated!
