More progress this afternoon.
First, my care package from Chris arrived today with some of the missing parts from this assemblage of random bits - the elusive tach drive thrust washer, 4 freshly vapor blasted front motor mount bolts for the 5 speed lower case width, the right intake cam bearing and the drain plug, and he even provided a new o-ring for the drain plug too. That's the thoughtful guy he is.
Torqued the main bearing cap, did one final visual check of everything and got out the new tube of Hondabond. Lightly slathered up the clutch rod seal and the countershaft seal, put them into place just after this pic and then put sealant on the lower case.
A little flash rust on the windage tray, no big deal. I used some of the phosphoric acid to clean it up previously, it was a lot worse.
Torqued the lower case bolts (no I did not use the in-lb wrench on the 6mm bolts, just my hand), flipped it over and put the last four 6mm bolts in the top. Dragged out the engine stand Chris gave me years back and slipped the bottom end into it. Since my front motor mount plates are repainted, I just put a block of wood under the front of the lower case, plenty stable enough.
At long last, machinist Russ's lathe-made starter hole plug got installed. He didn't machine an o-ring groove into it, so I found one in my Dad's huge old selection of them and added a tad of Hondabond on the o-ring. Russ drilled and tapped it (1/4"-20, and when I asked him if he used a metric bolt he told me only SAE hardware in his shop, LOL). Not feeling overly trusting of a coarse thread bolt on the inside of the engine, not that it could actually go anywhere if it did come loose, I bought an external star washer for it and used a little drop of loctite on it as well.
I was a little sloppy with the Hondabond
At that point my back told me it was time to quit. But I did snake the cam chain around the crankshaft before I called it a day. Literally forgot to do it before the main bearing cap after having the crankshaft in and out 3 times.
