Engine mount spacer
Emlupi
CT
Good afternoon,
I am missing this part from my ‘73 CL350. It is pretty much unavailable everywhere. Was wondering if someone could provide the dimensions of this spacer so I can try and find an alternative or fabricate a replacement. Many thanks.IMG_6502.jpeg
Do you have the part number? Sometimes other people can find stuff on line we miss.
I just checked the usual suspects including David Silver, nothing.
Part number 50329-286-010
Shouldn't be too difficult to find something suitable for it though, it's not anything exotic.
50329-286-010 up to K4, for sure. I'll go measure my loose basket case one (K2) and try to check length on my 73 CL350.
EDIT: Wouldn't cha know. It's missing. Anyway, it's 12.5mm long and 24mm outer dia. with a 10mm bolt.
I have just used a stack of flat washers when a spacer has gone missing on a project. Not right but will work until you come up with the right one. I usually have to use a combination of thick and thin washers to make it fit the space.
Many thanks all. If I can’t find one I will make something to fit.
Is it made of steel or aluminum? I assume it’s made of steel.
Thanks plenty, definitely can do. You can PM me the address and I will take care of it.
Some days I swear I could ruin an anvil with a rubber mallet.
I was digging around in a box of spares that came with my bike and, lo and behold, lookie here what I found.😃IMG_6563.jpeg
Well, I guess now I have two.
