OhioBackRoad
Here's where I'm at...
When I got the bike, (less than 7000 miles on the clock), it started and idled well but ran like crap. Looking at the carbs they were in dire need of a good cleaning and the manifold and carb-to-manifold o-rings needed to be replaced.
With that done, I did a compression check and it was not the best. As the bike had been sitting for years I took a look in the cylinders and all seemed well so I thought a bit of exercise might free up the rings and bring back some compression.
It took a bit of adjustment to the carbs to get the bike running well enough to put some miles on it, and it currently starts well and runs well up to about 7000 rpm or 55 mph in 5th gear.
I haven't done a leak down test, but as the bike doesn't smoke and isn't using a noticeable amount of oil, I'm thinking perhaps it's an issue with the valves. With that said, I'll most likely do the test before getting into the engine. I'll likely continue to ride the bike until bad weather hits and then pull the engine and go through it.
My question is, is there a right way as opposed to a wrong way to remove the head to do the valves followed by a hone of the cylinders and new ring installation? Any and all pointers and suggestions would be most welcome.
