CL450 K1 Rescue
brewsky
bluefield va
This one followed me home.....
I was considering consolidating all my old bikes into one new smaller one and spotted this one so I couldn't resist!
Original owner, 6700 miles, been sitting for years, so here we go. He said the carbs and service were done last year and it started up but the clutch was stiff and I took a chance without actually riding it
Nice find! Even the tires look relatively good for a bike that's been sitting - although I'd still be wary if they're way out of date. Looks like an aftermarket clutch cable, so I'd check the routing of it to make sure that's not contributing to the stiff clutch, although it could just need to have the cable lubed and the lifter greased.
I lubed the clutch cable till oil dripped out the bottom and cleaned and re greased the lifter mechanism. I thought maybe the ball bearing was missing from the actuator rod the way it was acting but it was there.
Adjusted it up till it felt good and took it for a short ride. After a few blocks it started acting sticky again and the plates started sticking open......never had that happen before!
Could be cable routing, which gets a little fiddly coming through/around the carbs. Possibly just everything being gummed up with old oil or the clutch basket has some wear on the fingers and it's not allowing the plates to slide freely.
Tires were new last year and date code is 3323 so they should be good....and they are the correct inch sizes
  • Like
Reactions: J-T
Cables can stretch with heat, but that usually works to make the clutch less responsive. Might be time to pop the side cover off (don't forget to acquire a replacement gasket in advance) and check the clutch basket. Might be a good opportunity to clean the plates and discs.
cable routing looks good and the sticking got worse as the engine got warmed up? Seems backwards?
If the inner sheath is worn through (around the inner cable) then it's time for a new cable, as no amount of lube will help in that situation. It could be an aftermarket replacement cable that did not have an inner sheath, in which case the inner cable eventually gets rusty and causes more binding. I had a bit of a difficult pull on my 450 clutch lever despite a good quality new cable and no tight bends, and nothing I did helped except this stuff. It REALLY works well. Pricey, but worth it.
I reused my clutch plates and discs after giving a good soak in kerosene and clean with brake fluid. The fingers on the clutch basket was notched a bit and required lightly filing to clean up. Cleaned and lubed the adjuster with new cable and has been working great.
Is this the stuff from the link?
It says it is temporary and quits working when it dries?
My cable has no inner sheath
That's the stuff, and trust me it doesn't fade away. Not even sure why they say it's temporary, it's still working just like a year+ ago on my clutch cable, 30% to 40% easier to pull when cold or hot (though my cable has always stretched when hot regardless).
may be worth a shot.....I always used the baggie of oil suspended from the ceiling method on my old bikes.
I assumed the cables were original but you never know for sure I don't remember any sheathed inner cables back then
Trust me, it works. And I only used a little bit, just enough to be sure it would go most of the way through the cable.
Yes, there were sheathed cables back then, AND the OEM cables on all Hondas during that era were gray. The black cables started somewhere in the mid-'70s, not sure any of the CL450 line got them until maybe the K6
Why I hate tank liners!
Oh, so gross. All these horror stories. I've switched to simply removing the rust with electrolysis using an old school car battery charger and calling it good. Nothing further needed, and one should reasonably be using fuel filters anyway
I had hoped to rebuild the original petcock but one inlet tube is broken off so will have to sed about fixing ghat later.
Time for a vinegar bath on some crusty parts before paint or zinc plating
100 roofing nails to stir up any loose rust or whatever else is left inside
You need to be really careful using nails. It’s very easy to puncture the thinner parts of the tank when shaking.
I had hoped to rebuild the original petcock but one inlet tube is broken off so I will have to see about fixing that later.
The broken off inlet tube your petcock is missing is actually the "Reserve" inlet and is a tubular mesh screen that's like half the height of the solid brass inlet tube beside it.
Seeing that new genuine Honda petcock valves are still available for your CL450 from Honda Powersports dealerships for ~$70+,
I took the part number (16950-292-000) shopping at eee Bay and stumbled upon this :
No doubt that can happen! I put about 15 pinholes in a tank once by forgetting to check the vinegar bath for a week!
I feel pretty good about this one though, it really didn't look that bad inside and I mostly slid the nails back and forth
Thanks, that's very tempting! I already ordered a repro from Scrambler Cycle but I hate to throw anything away!
