Just google... Perfect, thank you!!Where did you get that image? It doesn't look like either the early or late style for the dohc 450.
Possibly sohc 450 of the 80's? Edit : Yeah, it looks like your image shows the screw for an 80's sohc 450.
You should be fine with the one you have.
Those are VB22 mixture screws for the SOHC 450 enginesIf they look correct, are they worth replacing? I was thinking that this is the style I should have, so glad y'all know!
Yours looks correct, can't tell for sure if it's OEM. Others here may know for sure. The fuel/air screws in my CL450 K6 carbs are aluminum, not brass, are stepped like yours (not tapered like some replacements) have a tiny aluminum washer between the o ring and spring. So, I'm not sure if mine are OEM or not. The OEM complete set may still be available from Honda, listed as Screw Set A in the carburetor diagrams
HONDA OEM SCREW SET A | 16016-346-004 (check to be sure it's for your model year)
and the washers alone are available from 4into1 as a pack.
Carburetor Tuning And Air Mixture Screw Washer - 50 Pack
4into1.com
Parts and accessories for vintage Honda motorcycles from the 60's, 70's & 80's.4into1.com
Hmm, im 99% sure I do, but I will check and make sure.Are you sure you have the original carburetors on the bike? I had a correct 723A and a not correct 14H on my K5 where the PO had swapped it out. A lot can happen in 50 years.
I bought this kit, and couldn't find them...only the rubber washer. Ill check back through my stash too and see if I just missed them.However, 4-into-1 does seem to include the screw, washer, and o-ring in their carb kit for the 450.
