You can check resistances easily.
Yellow - Green primary wires are under 1 ohm
Plug wire to plug wire w/o caps 8K ohms +/-.8
Plug end caps 5K ohms
OK...........
I just tried to check the resistances, and...........
I disconnected the coils, zeroed my ohmeter and touched yellow and green, and it was under 1 ohm.
I removed the caps from the wires and didn't seem to be able to get any reading?
I put one lead in to one wire end, and the other in to the other end and didn't seem to be able to get any reading?
My tester was purchased in 1985, so..............
And being as I am niot very good with electrical.........
It is very likely that I did something wrong?
One reading out of three is where I am at.
bob
p.s. - one question....
do the plug wires thread out of the coil in the same way that the plug cap comes off of the wire?
I didn't want to try this in case I goofed something up, I'm a rookie at best when it comes to electrical.
