Stan Lipert
Hi, I'd like to share my CB350 engine rebuild video:
This is my long format (three hour!) video demonstrating a recent engine and carb rebuild, including some cleaning, inspection, refinishing and assembly with test run. Although not completely comprehensive, it is a rebuild of an actual engine in my home shop.
Time stamps will help navigate to your chosen viewpoint:
00:00:00 Introduction
00:00:25 Head disassembly
00:02:57 Cleaning the head
00:04:13 Bead blast cabinet
00:06:18 Prep for blasting
00:10:28 Clean the vales for inspection
00:12:18 Valve guide replacement
00:17:18 Ream valve guide
00:19:07 Measure the valve guide wear
00:19:32 Cut valve seats
00:22:05 Lapping valve seats
00:23:59 Inspect valve sealing
00:27:29 Valve spring inspection
00:29:32 Install the valves
00:32:34 Cleaning the crankshaft
00:36:36 Inspect the crankshaft
00:37:51 Crankcase inspection
00:39:43 Kickstarter
00:42:36 Crankshaft installation
00:46:12 Transmission
00:52:50 Bottom crankcase
01:00:34 Oil seals and neutral switch
01:02:56 Shift drum locator
01:04:55 Shiftshaft
01:06:45 Clutch plate inspection
01:07:48 Clutch basket
01:08:15 Oil pump
01:09:40 Primary drive gears
01:12:22 Clutch plates
01:16:17 Oil filter
01:19:43 Electric starter
01:28:27 Starter motor installation
01:34:31 Left engine cover
01:39:06 Clutch cover
01:44:37 Piston and cylinder inspection
01:46:36 Cylinder honing
01:49:19 Piston measurement
01:51:26 Piston ring end gap
01:51:57 Piston ring installation
01:52:41 Piston installation
01:56:50 Camchain tensioner rollers
01:57:50 Cylinder installation
02:02:42 Head installation
02:04:24 Camshaft inspection
02:06:16 Cam sprocket
02:06:49 Cam box
02:07:55 Tachometer gear
02:08:52 Cam bearings
02:09:36 Rocker arm inspection
02:10:14 Camshaft installation
02:13:54 Rocker arm installation
02:17:45 Top engine cover
02:22:04 Camchain tensioner
02:24:50 Valve adjustment
02:27:22 Ignition points
02:37:30 Stator cover
02:38:36 Sprocket cover
02:42:56 Carburetors
02:58:00 Ready to bench run
02:58:24 Ignition timing
02:58:44 Shifting test
02:59:13 Compression test
02:59:29 Cold start
I'm not making money from this, just a guy in his shop with a cell phone and tripod.
Enjoy!
Stan
01:04:55 Shiftshaft
01:08:15 Oil pump
01:16:17 Oil filter
02:06:49 Cam box
02:59:29 Cold start
Enjoy!
Stan
