Jim sent me Rex's unit to compare. Some very interesting comparisons with regards to cost cutting moves. If you want the real deal that just works you can always order it from me.
Size comparison of my case and their case. Theirs is thin plastic and is actually longer in length
Size comparison of my unit and the bracket. As mentioned before, this interferes with valve adjustment. Rex's unit is zip-tied onto this bracket. This means that eventually UV exposure will weaken those zip ties:
Potting compound on one of the canon plugs:
Large amount of potting compound on the side of the plastic case:
Poor quality crimps, not even crimped the whole way. Jim mentioned that one of the crimps already failed when he was removing the unit to test mine:
More of the poor quality crimps. Notice the brown wire is already exposed from a few times of disconnecting it. Now that it's exposed it's more likely it will build corrosion at some point:
The wires themselves are the incorrect colours or shades in some instances. The wiring itself is also a smaller gauge compared to OEM and my unit.
The sleeving is not the glossy PVC type as OEM or my unit. It appears to be flat heatshrink tubing. I'm unsure if this electrical tape (not harness tape) is a repair from Jim or from Rex's:
The B/W bullet plug is supposed to come out of this hole where the electrical tape was. Again, if this was Jim doing a repair, please let me know and I will remove mention of this. If Rex's did it, then this is wrong and they put electrical tape over it to hide the fact they cut too short:
Once I get some more professional pictures done of the unit I intend to remove the potting compound and see what components are in there. The potting compound is similar to what I use, but is poorer quality.
