wentwest
Success! The combo of the courage to grind a bit more and using a punch to drive the pins back and off came the link. So I went to it on the new chain and that one went much easier because I wasn't so ignorant of how it works. Thanks to everyone.
I draped the chain over the sprocket on the crank and sealed and then put the two pieces together. How do I know how much cam chain to leave free on each side. I know the assembly ends with putting in the master link at the intake camshaft sprocket, so I left a lot more toward the front of the engine, but that's just a guess. Is there a system? I could put on the magneto rotor temporarily and set the crankshaft at LT, rotate it 90 degrees counterclockwise and if I knew how long the chain should be on one side before I put on the cylinders it would be helpful.
